guys i had a problem with my engine when you start the engine is on normal idling but after you reach the normal engine temperature the engine start high and low idling,
thanks
adjust the high and low idle screws located near the throttle body. that should solve it. if you have any troubles just drive to your nearest toyota dealer and ask them how and where they are.
