Block heater
Block heater
Postby Brui » Mon Aug 16, 2004 3:57 am
where is the plug for the block haeter is located? thanks
Silver 1990 ST185
Red Deer, Alberta, Canada
Brui
Postby Gary » Mon Aug 16, 2004 5:24 am
Correct me if I'm wrong, I don't think alltrac has a block heater.
93 ST185
Gary
Postby ChrisD » Mon Aug 16, 2004 3:40 pm
edit
1988 ST165
1994 ST205 WRC
ChrisD
Postby wingnut » Mon Aug 16, 2004 5:49 pm
If you mean the core hole plugs, there are four in front and four in the rear just below the cylinder head. The fronts are easier to get to but you'll have to remove the turbo to reach one.
Keep it simple stupid
ST165
wingnut
Postby Brui » Mon Aug 16, 2004 7:34 pm
what do you Chris do in winter? what I was told by mr2 board I can use #3 cylinder frost plug but it is a PITA to get it out, I just wanna to double check
Silver 1990 ST185
Brui
Postby Dano » Thu Aug 26, 2004 5:18 am
When I got my ST165 a few months ago I asked my Toyota dealer about installing a block heater and they suggested that I wait until the car needed new turbo seals or other work because the turbo had to come off and other stuff and it would be a 4 or 5 hour job.
I later discovered and electric plug in the engine bay and so I learned that I already have a block heater. The original owner was a doctor from Lethbridge, Alberta.
'88 red Celica Turbo 4wd--for sale $1500
'93 yellow MR2 Turbo
'91 red Dodge Turbo diesel 4x4, with pop-up custom camper
'97 white 4Runner 4x4 SR5 "creampuff"
Dano
Postby ChrisD » Thu Aug 26, 2004 2:07 pm
edit
1988 ST165
1994 ST205 WRC
ChrisD
Postby Stubble » Fri Aug 27, 2004 2:30 am
I live in Winnipeg, which is just a few degrees warmer than antartica in the winter. When my rad cracked one night at -42C, i decided I needed to do something. Too expensive to put a block heater in (it goes in the front of the #3 cylinder). I ended up putting an inline heater into my lower rad hose. I just rebuilt my engine, and I still didn't bother with the block heater - I'm just going with the inline heater.
Brady Ryall
1990 ST185 Red - parts
1990 ST185 Black
1999 Miata
2008 A3 Quattro S-line
Stubble
