600 hp TMIC?
Re: 600 hp TMIC?
Postby pinoyGT4 » Sat Jan 23, 2010 10:53 am
Mafix wrote:anything is possible with enough money.
that's true..
and patience also... 8)
Making your car track worthy is making it more than road worthy
www.grupotoyota.com.ph
pinoyGT4
Re: 600 hp TMIC?
Postby IStalkgt4s » Sat Jan 23, 2010 9:11 pm
I suppose, but I'm no millionaire... So I gotta figure out big power for low budgelol
1990 st185 -Jayne- (Project)
1988 st165 -Susan- Daily Driver
2008 Tacoma -Maria- PreRunner
IStalkgt4s
Re: 600 hp TMIC?
Postby Mafix » Sun Jan 24, 2010 3:20 am
as bad as this sounds
big power low budget = honda civic
big power high budget = gt4 or 3kgt
of course the sky is the limit
Re: 600 hp TMIC?
Postby IStalkgt4s » Sun Jan 24, 2010 3:32 am
Well, we will see how my build comes out lol
IStalkgt4s
Re: 600 hp TMIC?
Postby IStalkgt4s » Wed Aug 21, 2013 4:02 pm
Just to let everyone know. I'm at 400awhp at 18psi with a st205 intercooler on pump gas no problem. Doubt it? Call kris at KO racing :)
Add e85 an more boost?
500 hp here I come
Eventually I'll get the build on here
IStalkgt4s
Re: 600 hp TMIC?
Postby quieter » Wed Aug 21, 2013 8:29 pm
sweet! what heat exchanger and pump your using?
2011 BMW 535xi M pack (daily)
-Simon
quieter
Re: 600 hp TMIC?
Postby Tecker185 » Wed Aug 21, 2013 9:17 pm
Also very interested in your setup post up your parts list.
89 ST165
89 SV25
86 AW11 2zzge swapped
86 AE86 1uz swap
89 AE95 sedan
89 AW11 Supercharged
17 4runner TRD Off Road
Tecker185
Re: 600 hp TMIC?
Postby IStalkgt4s » Wed Aug 21, 2013 9:45 pm
I'm using a st205 top mount with an aftermarket SVT cobra heat exchanger... Also an SVT cobra pump...
Forged 2.0 2nd gen block
3rd gen head with kelford 270 cams
Precision 5150
880cc Injectors
IStalkgt4s
Re: 600 hp TMIC?
Postby IStalkgt4s » Wed Aug 21, 2013 9:48 pm
IStalkgt4s
Re: 600 hp TMIC?
Postby IStalkgt4s » Wed Aug 21, 2013 9:49 pm
not the best pictures sorry
IStalkgt4s
Re: 600 hp TMIC?
Postby CSAlltrac » Wed Aug 21, 2013 11:18 pm
IStalkgt4s wrote:Just to let everyone know. I'm at 400awhp at 18psi with a st205 intercooler on pump gas no problem. Doubt it? Call kris at KO racing :)
500 hp here I come
Guessing this was done in 2WD mode.
Re: 600 hp TMIC?
Postby BriinumsBo » Thu Aug 22, 2013 7:34 am
I had ARC, check www.turbocelica.lv
Excellent quality but 550hp? No. 450 i would say
While it would work, you would get much better/safer temps with fmic.
ARC exchanges heat quickly but also heats up quick if you are not moving, so you need a fan on top of it, which also cant help enough because the IC is literally sitting on an oven called 3sgte. I also installed liquid squirters attached to the bonnet. Its pain in the ass, even subies dont do tmic at such target numbers, while their TMIC is set back behind the "oven" by a great margin..
I must admit the st185 bonnet looks cool with arc ic underneath, i like it better than RC bonnet looks :D
Another option is to implemet liquid co2 spray system on the tmic, but that depends on your needs because it is also PITA
BriinumsBo
Re:
Postby 4rsnduction » Thu Aug 22, 2013 8:12 am
celicaGTS_T wrote:rumor has it that ARC made a top-mount that would fit the 'trac's.... good luck finding one tho l :lol:
.... seriously, they did.
I know, i got one, its a little sore looking but works :)
Amazing what you find on yahoo japan auctions
4rsnduction
Re: 600 hp TMIC?
Postby brutekiller787 » Thu Aug 22, 2013 2:27 pm
If Your Going To Do A Co2 Spray Might As Well Do It On A Front Mount Because They Make Kits For it.
brutekiller787
Re: 600 hp TMIC?
Postby ___Scott___ » Sun Aug 25, 2013 9:13 pm
IStalkgt4s wrote:Also an SVT cobra pump...
Quick question, does the SVT cobra pump fit in the stock IC pump bracket or did you have to fabricate a bracket to make it work?
My IC pump is dead and I'm considering swapping in the SVT cobra pump since they are cheap and easy to find.
Scott
Colorado Springs, CO - USA
SONY
Opera - The better browser
___Scott___
