i was hoping you guys could just gimme general info on these two turbos. i know it also depends on your overall setup as well, but i'm only looking for a general answer to this. for instance, i know the ct20 spools as fast if not faster than a stock ct26 but holds boost to redline better. how do the spooling characteristics, turbo lag, and boost hold compare with each other? thanks in advance-
