ct20b vs tdo6sh
ct20b vs tdo6sh
Postby burden » Mon Aug 16, 2004 5:41 am
i was hoping you guys could just gimme general info on these two turbos. i know it also depends on your overall setup as well, but i'm only looking for a general answer to this. for instance, i know the ct20 spools as fast if not faster than a stock ct26 but holds boost to redline better. how do the spooling characteristics, turbo lag, and boost hold compare with each other? thanks in advance-
burden
Postby Zeus » Mon Aug 16, 2004 5:11 pm
http://www.members.shaw.ca/zeusbb/Info.htm
my personal thoughts on the turbos ive seen
in short
ct20b is great for low power high response...
td06 is good for straightline power on the cheap
Blake Brown
Zeus
Postby burden » Fri Aug 20, 2004 5:53 am
holy hell, that writeup is awesome, ty
burden
Postby gt4tuner » Fri Aug 20, 2004 1:20 pm
Zeus, have you gotten your GT30R yet. If so where did you get it from, and are you getting rid of the GT25 kit :wink: ? I know the GT30 kit from www.extremeboost.com won't fit because of clearance problems with the external wastegate and the alternator, but if you found another source for the turbo alone I wam very interested.
gt4tuner
Postby Zeus » Fri Aug 20, 2004 3:43 pm
im using the gt3040 not the gt30r.. i have allready gotten rid of the gt25r kit did so a long time ago...
and i got the turbo and ewg from extremeboost...; im ruinning the ats adapter kit to fit the turbo and ewg
Blake Brown
Zeus
