hp with stock block and new intake/exhaust
Postby reaper0995 » Mon Jan 10, 2005 9:30 pm
I have a '92 alltrac and was wondering if I were to have 3in exhaust custom header, front mount intercooler, and cold air intake, what kind of hp would I most likely be able to make? If I were to have that and cams, what then? Any other suggestions of modifications that would help a lot? stock turbo as well
reaper0995
Postby Gary » Mon Jan 10, 2005 9:39 pm
You won't go far with stock turbo.
250hp give or take.
No fuel upgrading?
How much boost are you planning to run?
93 ST185
Gary
Postby reaper0995 » Mon Jan 10, 2005 9:50 pm
i am planning on 14 psi
reaper0995
Postby BraveUlysses » Tue Jan 11, 2005 12:26 am
Take it to a dyno. Estimating horsepower is, simply put, something ricers do.
BraveUlysses
Postby etantshi » Tue Jan 11, 2005 1:00 am
My money is on 230 max to the wheels.
André B.
1991 ST185 (down but not out)
1996 RZN140 (the daily)
etantshi
Postby 92 All-Trac » Fri Jan 14, 2005 4:56 am
Actually, estimating horsepower is the right way to go about a project. You just have to do it the right way. Look at all the professional builders. They always set out a plan for desired hp and do the research and testing for the right combination of parts.
I'd say you could squeez around 250 maybe if you went up a couple pounds of boost. You would be at the limits of your fuel and flirting with danger though.
Josh
1992 ST185
92 All-Trac
Postby OlyST185 » Fri Jan 14, 2005 8:26 am
i would say to not be so optimistic when talkin about estimated horsepower.
so you never get disapointed.
i would estime around 250-260hp with those mods... maybe 15-20 more with cams, but id change for a bigger turbo instead of cams... changing cams take bigger benefits when you already have more mods.
-Oly (Montreal)
3SGTE'S POWER, 4WD SUPREMACY
[img]http://olyst185.multimania.com/turbo4wd.jpg[/img]
-ST185 1990 Black. RC/CS Conv.
OlyST185
