Vaportrail
New member
I brought my car back from the shop the other day. Since then, the turbo will not kick in. As of now, I have a faulty o2 sensor... could this be the cause of the turbo problem? I also had my mid-pipe replaced... the shop says they think there's a flow problem in the new pipe, and that may be what is causing my turbo not to work.
Might either or both of these problems cause my turbo not to work? The wastgate is operating as normal. Not stuck in either postion. :shrug:
Any help is greatly appreciated.
