3SGE intake manifold on a 3SGTE??
Postby trd-at » Mon Feb 01, 2010 1:32 am
So i was wondering if anyone out there has done a 3sge manifold on their 1,2,3 gen 3sgte in a 185. I was also wondering if this swap will prove any gains or losses in power? Does iot bolt up to the gen 2 head? Any answers in this direction would be helpful. Thanks all
trd-at
Re: 3SGE intake manifold on a 3SGTE??
Postby bccentaur3 » Mon Feb 01, 2010 3:09 am
Gen 1 head (5sgte) . Will also bolt up to Gen 2 head. makes it cleaner and easier to do tune-ups.
bccentaur3
Postby TRDcelica90 » Mon Feb 01, 2010 10:56 am
you have to get it off a 3sge that has TVIS it will bolt straight up.. side feed dont lean out cylinders like our shit 3sgte manifold.. also the 3sge has a bigger opening.. im def doing it!!
1990 Toyota Celica GT-FOUR RC Now with the power of a Garrett GT30!!
1987 Toyota Celica GT-Four ST165 Rally car in the making..
TRDcelica90
Postby trd-at » Mon Feb 01, 2010 7:11 pm
Where can i find on of these manifolds?? any ideas? i have looked around and have no luck. Thanks guys!!
trd-at
Postby trd-at » Mon Feb 01, 2010 7:21 pm
also, what year or generation did this intake manifold come on?? What cars in the us or foreign?
trd-at
Postby bccentaur3 » Mon Feb 01, 2010 8:15 pm
86-89 celica GTS with the 2.0 3sge motor. Can be found at breaker yards. I picked up 2 from there.
bccentaur3
Postby ct27gt » Mon Feb 01, 2010 8:36 pm
There was a thread about it over on mr2oc where a tuner named RickyB (I think) was involved in where the guy said he was able to take out fuel and add timing on cylinders 2 and 3 cuz they weren't leaning out anymore. So yeah, better air distribution. Not only that but it keeps the IC piping away from the valve cover which is a huge plus.
92 Celica GT (3sgte swap)
ct27gt
Postby TRDcelica90 » Tue Feb 02, 2010 1:36 am
I just bought one from another state for $50 delivered, so there a bloody bargain.. a local wreakers nearby mine sells them for $22.. but i CBF taking it off plus the one i bought it a JDM so i dont have to block the EGR for my jap motor!!!
so yes the 162s with a 3sge that HAS TVIS!
TRDcelica90
Postby trd-at » Tue Feb 02, 2010 1:24 pm
great info, thank you! Well i will try to track one down here in colorado. If anyone finds on please let me know, thank you
trd-at
Postby Mafix » Tue Feb 02, 2010 4:40 pm
note this can only be done on gen 1 and gen 2 3sgtes.
the intake manifold comse off a 4th gen celica GTS (sx). or for others the first gen 3sge.
Postby BNZ » Wed Feb 03, 2010 10:09 pm
TRDcelica90 wrote:y.. im def doing it!!
+1
Street ST185
Rally ST165
HillClimb Renault 5 GTE
BNZ
Images: 31
Postby DudeMan » Wed Feb 03, 2010 10:46 pm
Mafix wrote:note this can only be done on gen 1 and gen 2 3sgtes.
What all had to be modified to use this manifold?
I'm pretty sure the stock braces wont work, what about the vacuum lines on the back?
-Chase
1990 4Runner SR5
1990 Celica GT-Four
DudeMan
Postby bccentaur3 » Thu Feb 04, 2010 12:34 am
No vacuum ports on the back for me. All the vacuum ports are up front. I coudlnt use the brace on my set-up because its a 5sgte. All you have to do is notch the throttle inlet to match the iacv on the gte throttle body.
bccentaur3
Postby bccentaur3 » Thu Feb 04, 2010 12:36 am
Oh and the csi won't fit. If you can find the 3sge csi or any early 3sfe with csi will work.
bccentaur3
Postby redGT4 » Thu Feb 04, 2010 12:59 am
Interesting. There's a few gen 4's at my local wrecker. I'm gonna have to investigate them a bit more closely.
54 trim hiflowed ct26; Custom top mount;2 1/2" exhaust; Turbosmart boost controller(not fitted); Autometer CF series; Everything else stock; The Haunter of the Hills.
redGT4
