3SGE intake manifold on a 3SGTE??
Re: 3SGE intake manifold on a 3SGTE??
Postby mixer72 » Fri Dec 30, 2011 1:00 pm
here is mine ready to fit
here you can see the 2 temp sensors for the ecu and my charge temp gauge
full build viewtopic.php?f=44&t=34183
mixer72
Postby mixer72 » Fri Jan 06, 2012 7:39 pm
manifold is now fitted to the head:)
hear you can see the plate I had to make so that I can use the idle up valve and for there to be a back plate for the air bypass
mixer72
Postby mixer72 » Sun Jan 22, 2012 9:55 am
easy job i got mine of a st162 celica
mixer72
Postby tubasteve » Wed Mar 14, 2012 6:16 am
Can you use the injector rail as well?
3sge ->2nd gen head?
Just a thought.
tubasteve
Postby MrDB » Wed Mar 14, 2012 7:28 am
Yes rail fits as with 3sgte intake...
MrDB
Postby mixer72 » Wed Mar 14, 2012 11:15 am
Or you can boar out the 185 fuel reail to 8mm and then feed it from both ends like i have :) works rely well as you are sort of feeding 2 injectors from each side.
mixer72
Postby tubasteve » Wed Mar 14, 2012 2:40 pm
Done that, too noticeable. I live in California....
tubasteve
Postby mixer72 » Wed Mar 14, 2012 6:26 pm
Living in the UK we can do more or less any thing we want to are road cars. is it very strict over with u?
mixer72
Postby tubasteve » Wed Mar 14, 2012 7:48 pm
Cops, yes, past ticket customer paid was 783, and had to be checked by a government employee. Hard to find crooked ones too.
-jr
tubasteve
Postby Matty-st185 » Thu Dec 12, 2013 8:02 pm
Ok just reading this here I'm a little confused
Carlos sainz st185 ..3sgte is the car I'll have
Are people saying to take a non turbo st185 st205 3sge intake manifold
With (tvis) and it bolts straight on with mods required increasing airflow
To the 3sgte st185 engine
What are the power gains for this ?
1993 JDM Celica ST185Rally GT Four widebody
Matty-st185
Postby mixer72 » Thu Dec 12, 2013 8:25 pm
The manifold is from a st162 N/A and yes it just bolts on. You can port it if you like. Witch is what i did and you will neec to add a plate the throttle opening so you can use the idle up valve. They flow botter give a better pipe worl lay out. As for power gains carnt rely say as i dident do s back to back test. But when i had it maped my mapper just said it wanted more fuel. Witch meens to me it must be flowing better
mixer72
Postby UtahSleeper » Thu Dec 12, 2013 8:26 pm
I don't think the ST205 motors work with this.
The ST162, in the US anyway, had a 3sge engine with a side feed manifold. This manifold bolts up to a ST165 and 185 engine.
The reasons for this is:
-It fixes an air flow issue that leaned out 1 or 2 of the cylinders.
-Makes it so you don't have to run the intake over the engine and heat up the intake pipes.
-Not sure on air flow improvement for performance.
-Makes for a cleaner install of a front mount.
UtahSleeper
Postby MWP » Fri Dec 13, 2013 1:59 am
UtahSleeper wrote:I don't think the ST205 motors work with this.
Correct, they dont.
If you want side-intake on a gen3 engine, you'll need an intake manifold from a gen4 (Caldina ST215 or ST246).
Postby Mafix » Sat Dec 14, 2013 5:26 pm
you'd need a celica 2.0gti or 2.0sx from 86-89.
Postby celicast162v6swap » Wed Apr 29, 2015 5:25 pm
Been waiting years for this conversion and saving parts. Found this thread after I did mine. Only issue is to hog out the lower part of throttle body hole for the idle control to work properly... i got pics if needed? :D
88 celicaall-trac. New drag car project
87 celica gt-s once v6 turbo swapped and custom lights.
celicast162v6swap
Images: 9
