3SGE intake manifold on a 3SGTE??
Re: 3SGE intake manifold on a 3SGTE??
Postby loudstealthGT-Four » Sat May 02, 2015 9:47 am
No need for spacers just needs to have a slot shaven out of the bottom, similar to the factory manifold.
loudstealthGT-Four
Postby celicast162v6swap » Sat May 02, 2015 6:26 pm
Nice... that's what mine looks like and I did it before I seen it on all-trac.net. I been saving a n/a intake and cams for this conversion for 5 years.. :crazy:
88 celicaall-trac. New drag car project
87 celica gt-s once v6 turbo swapped and custom lights.
celicast162v6swap
Images: 9
Postby buffalohunter7321 » Fri Jul 17, 2015 4:34 pm
I have a 88 GTS 3sge head and the side mount intake mounted on a 88 3sgte block. I could use some help on connecting every thing up on the intake. Is there some one that could help me out with all the hose connection on the bottom of the throttle body? Which ones are water and vacuum and where specifically each one goes to what.
Jack
buffalohunter7321
Postby celicast162v6swap » Fri Jul 17, 2015 6:55 pm
The big 1/2 inch vacuum on the right side of t/b is the idle control it goes to the air flow meter tube or inlet to turbo. The water line on the left side of the t/b goes to the thermostat housing the right side one goes to the heater hose tubes. There both 3/8 hoses. The little vacuum on left side goes to the valve cover tube. Any more help let me know mine runs beautiful. :shoots:
celicast162v6swap
Images: 9
Postby buffalohunter7321 » Sat Jul 18, 2015 12:27 am
Thanks Bro, I hope mine runs as well too.
Jack
buffalohunter7321
Postby buffalohunter7321 » Sat Jul 18, 2015 1:56 pm
Can I use a 3sgte valve cover on this 88 3sge Head or do I have to stay with the two 3sge covers?
I kind a want to use the 3sgte one because it is powder coated. The others are just stock gold color.
buffalohunter7321
Postby celicast162v6swap » Sat Jul 18, 2015 7:31 pm
I can tell you that the valve cover gaskets are the same. The difference in the heads is the gte has different cams and it has extra tabs on the head for the intercooler. Set it on the ge head and see if the bolt holes line up It should fit. The na cams are bigger atleast mine where and work awesome.
celicast162v6swap
Images: 9
Postby buffalohunter7321 » Sat Jul 18, 2015 10:37 pm
I was told that the 3sge cams give you about 10 hp. more over the 3sgte ones. So I'll check and see which I will be able to use.
Brute Killer was the one who did my build and also guided me through some awesome mods. He said he would do my build write up, but since he moved back home to N.Y. and working as a mechanic along with two babies and a wife. He doesn't have much time to punch keys on a key board.
Some day I'll get it back together. Jack
buffalohunter7321
Postby celicast162v6swap » Sun Jul 19, 2015 6:15 am
I can't tell you h.p gains on the cams.lol I have a no name stamp or numbered n/a head I stole the cams from. The intake cam was about .006 inc bigger and the exhaust was .010 inc. It feels like more h.p before boost to me at 12 degrees of timing. Took me a month motor pulled n striped down to short block 185 head 89 n/a cams and intake n header ct26-16g and 3" dp clutch and all seals.. :D
celicast162v6swap
Images: 9
Postby celicast162v6swap » Sun Jul 19, 2015 6:21 am
If you can help.. how I can wire my fuel pump relay wiring to send 14 volts to my new aeromotive 340lph pump I installed. It runs but the directions say to hook a wire from the alternator to a relay and then to the pump. I can't find the info
celicast162v6swap
Images: 9
Postby buffalohunter7321 » Mon Jul 20, 2015 2:41 am
Give me a few days to look up what brute killer had me to do so that my engine as 14+ pressure at all times. No gas starvation from start up to shut down.
I'll post up every thing he gave me.
Jack
buffalohunter7321
Postby celicast162v6swap » Mon Jul 20, 2015 4:21 am
That would be awesome. I wired a relay in the trunk but I don't like having 2 relays for a fuel pump.
celicast162v6swap
Images: 9
Postby buffalohunter7321 » Mon Jul 20, 2015 7:15 pm
"Fuel Pump Relay Mod."
The fuel pump relay in the st165 is located on the rear firewall behind the inlet manifold and is clearly labelled ...there is a yellow connector just below it... locate the wires that go from the connection to the relay... Bridge [cut] the blue with orange stripe wire with the blue and black stripe wire...This will insure fuel pump receives 13.5 volts all the time... Job done.
Unplug the resistor box [finned box] at the top drivers side corner near the windshield or leave it plugged in, it doesn't matter, it is being by passed.
Just leave the Fuel Pressure VSV. it has a round yellow conn. that comes right out behind and below the passenger side of the intake many. Just leave it unplugged.
The TVIS VSV, The Turbocharging pressure VSV, can be left unhooked, [IF] they have been removed.
02 sensor and the turbocharging pressure sensor, YOU must leave in.
Do you know about setting your intake cam one tooth before the timing mark and the exhaust cam one tooth passed the timing mark. This will open to let more gas air mixture in and also allow more exhaust out.
Ok that is all brute killer gave me, hope it works for you.
buffalohunter7321
buffalohunter7321
Postby celicast162v6swap » Mon Jul 20, 2015 7:42 pm
Much appreciated. I knew it was easy i just didn't want to fry my ecu or something else. You should put a sticky up for this mod it isn't on here anymore.... thanks allot for the advice.... do you live near seattle wa.
celicast162v6swap
Images: 9
Postby celicast162v6swap » Mon Jul 20, 2015 7:50 pm
I didn't know about the cams being offset for more hp. Ile have to try it and see how it works..
celicast162v6swap
Images: 9
