3SGE intake manifold on a 3SGTE??
Re: 3SGE intake manifold on a 3SGTE??
Postby celicast162v6swap » Mon Jul 20, 2015 7:57 pm
I see your signature says 7321 is that a 88 st165 body number. my 88 st165 hard top dark blue pearl is 7301. If it is your body number are cars are 20 cars apart on the assembly line.
88 celicaall-trac. New drag car project
87 celica gt-s once v6 turbo swapped and custom lights.
celicast162v6swap
Images: 9
Postby buffalohunter7321 » Mon Jul 20, 2015 8:52 pm
Not my cars #, just the # adds up to 13 seconds 1/4 mile run. Probably have to change it to add up to a 10 second run, after I get "The Black" going.
buffalohunter7321
Postby celicast162v6swap » Tue Jul 21, 2015 1:39 am
That's bad ass I didn't think about it that way.lol oh yea running 10s. I seen a black st185 on YouTube that ran 11s was that you. I like the 4wd burnout launch it did and want mine tooo...im drag racer also that video made me get one..
celicast162v6swap
Images: 9
Postby buffalohunter7321 » Tue Jul 21, 2015 2:44 am
Not me, I only have two 88 trac's. One has a main bearing knocking and 'The Black", I am still trying to get it back together.
As for "The Blue" I am going to convert it to be an all Electric car. No more gas fore that car. With the Electric Motor I am putting in it. It should be quite quick with around 1200 ft. lb. of torque on 4 wheels. Just hope the axles can handle it.
buffalohunter7321
Postby celicast162v6swap » Tue Jul 21, 2015 5:38 pm
That's cool. I've helped build a couple electric cars one called "coco loto" and the 280zx turbo "silver bullet" and the "dragon rose" drag bike that hold world records.. father time was are teacher and friend sad he is gone now... hope it works out for ya I've hear the tranny can hold 800 hp not sure on torque.
celicast162v6swap
Images: 9
Postby celicast162v6swap » Tue Jul 21, 2015 5:53 pm
Thanks for the fuel pump relay mod. I already jumped the wires and figured those where the wires i just wanted to know someone who has done it already. lol i would suggest putting a relay in the trunk and power from the battery 13.8 volts to pump now instead of 11.8 volts the stock system doesn't feed enough for my aeromotive pump. Also fuel pressure regulator vacuum straight to intake instead of using the vsv.. pulls hard now with 10 to 12 p.s.i of boost
celicast162v6swap
Images: 9
Postby buffalohunter7321 » Wed Jul 22, 2015 1:31 pm
Can you give specific detailed instruction on how to install the relay and what brand of relay did you use?
I am 67 and starting to loose my memory, that is why it is taking me so long on getting my "Black" back to gather, and that is the reason for asking for specific details. Thanks
buffalohunter7321
Postby celicast162v6swap » Thu Jul 23, 2015 3:35 am
No problem The instructions say:
Run a 10 gauge wire from your battery to the trunk with a 30 amp fuse or circuit breaker inline close to the battery.
Cut your 2 wire fuel pump connector out off the car.
Use your original fuel pump power and ground to excite the relay. Use 10 Guage wire from relay to the fuel pump.
On the relay hook up the terminals as marked:
#30 direct power from the battery with 30 amp fuse .
#85 original fuel pump 12v power wire in.
#86 oem fuel pump ground wire in.
#87 from relay to the fuel pump itself. blue w/black stripe. Then ground the fuel pump ground wire to the chassis ground behind trunk light plastic pannel.... Also just so you know the fuel pump in are cars only has power when your turning it over.
celicast162v6swap
Images: 9
Postby buffalohunter7321 » Sat Aug 15, 2015 12:22 pm
It's been awhile since we talked, but should I switch to a better fuel pump and still do the relay mod on the fuel pump?
buffalohunter7321
Postby buffalohunter7321 » Sat Aug 15, 2015 12:38 pm
Was going back over the last few threads and seen where you asked if I lived in Seattle WA.? I live in Dayton Ohio, but have a brother in law that lives there and works for Boeing.
I have tried to talk Him into buying a All-trac but he hasn't yet.
buffalohunter7321
Postby celicast162v6swap » Sat Aug 15, 2015 4:45 pm
I would do the fuel pump and relay mod just because they say the stock pump is week and fails. I was going to get a 95 tt supra pump but bought the new efi aeromotive fuel pump half the price. Pump isn't that much louder but definitely worth the upgrade.
celicast162v6swap
Images: 9
Postby buffalohunter7321 » Sat Aug 15, 2015 11:24 pm
That was my next question on what pump to use.
buffalohunter7321
Postby celicast162v6swap » Sun Aug 16, 2015 6:40 am
So far I like my aeromotive stealth efi 340lph fuel pump i feel it's worth the money i spent. I installed a few in a couple race cars and they work awesome too. I'm building a stroker motor for later so I got a better pump now. It depends on what you need really
celicast162v6swap
Images: 9
Postby buffalohunter7321 » Sun Aug 16, 2015 12:40 pm
Forgive me if I asked this before, where is your location?
buffalohunter7321
Postby celicast162v6swap » Sun Aug 16, 2015 4:38 pm
I live in seattle wa,
celicast162v6swap
Images: 9
