3SGE intake manifold on a 3SGTE??
Re: 3SGE intake manifold on a 3SGTE??
Postby DudeMan » Thu Feb 04, 2010 2:46 pm
So basically I should just grab everything when I get the manifold.
That's all there is to it? Just the CSI and IACV need to be modified?
-Chase
1990 4Runner SR5
1990 Celica GT-Four
DudeMan
Postby Mafix » Thu Feb 04, 2010 5:04 pm
dudeman i've used the stock 165 throttle body. the only thing you need 165 wise is the manifold and a steady hand. you have to cut a notch in the bottom of the throttle body inlet for the IAC.
Postby Mafix » Thu Feb 04, 2010 5:06 pm
just block off the CSI. it's not needed. easy enough there.
NOTE: my manifold has been smoothed out. it looks very different from the stock one.
Postby redGT4 » Fri Feb 05, 2010 3:49 am
So theres two similar types at the wrecker near me, one from a 3sge in an '88 just lying on the ground (someone took the head). And on the other side of the yard one from a 3sfe ('86 i think) was also lying on the ground. The 3sge was badged TVIS on top. I think i might have to go back and grab it. Price board says 4cyl intake manis are $19. :)
54 trim hiflowed ct26; Custom top mount;2 1/2" exhaust; Turbosmart boost controller(not fitted); Autometer CF series; Everything else stock; The Haunter of the Hills.
redGT4
Postby bccentaur3 » Fri Feb 05, 2010 4:57 am
I paid 12 for mine haha.
bccentaur3
Postby TRDcelica90 » Fri Feb 05, 2010 8:33 am
redgt4 grab the 1 that says TVIS.. thought u wanted to go top mount though
1990 Toyota Celica GT-FOUR RC Now with the power of a Garrett GT30!!
1987 Toyota Celica GT-Four ST165 Rally car in the making..
TRDcelica90
Postby redGT4 » Fri Feb 05, 2010 7:39 pm
^ i did, but if i upgrade the engine next year or after, then i wouldn't mind getting this side throttle intake. I mean i can just pick it up off the ground and walk away.
redGT4
Postby vip09 » Sun Feb 07, 2010 7:01 am
If you use the 2nd gen 3S-GTE throttle body you will need to block the idle adjustment area off on the throttle body as it will overlap over where it mates with the intake manifold flange.
vip09
Postby built2run » Sun Feb 07, 2010 7:51 pm
so does this hold true for gen3 to gen3? because they look way different i have been concidering a greytop intake manifold
ST165, black: parted and gone
ST165, white: sold to friend
built2run
Postby Mafix » Mon Feb 08, 2010 4:06 pm
does not work for gen 3 or 4. ONLY gen 1 and 2.
Postby bccentaur3 » Mon Feb 08, 2010 4:25 pm
vip09 wrote:If you use the 2nd gen 3S-GTE throttle body you will need to block the idle adjustment area off on the throttle body as it will overlap over where it mates with the intake manifold flange.
i think you're referring to the gen 3 3sge intake manifold to the gen 3 3sgte intake manifold correct? If so, yes they share the same bolt pattern, although I wouldn't know if there would be clearance issues. I believe the 3rd gen and 4th gen all share the same bolt patterns intake and exhaust side. Thats why you see some 3rd gen 3sgtes with 4th gen caldina intake manifolds.
bccentaur3
Postby trd-at » Mon Feb 08, 2010 6:40 pm
So i found one at a junk yard, 100 shipped in colorado.
trd-at
Postby vip09 » Wed Feb 10, 2010 9:25 pm
NO, I'm talking about the throttle body to intake manifold flange.
vip09
Postby Gary ST165 » Wed Feb 10, 2010 10:59 pm
This ST162 3sge manifold was modified for use with the ST185 TB and factory idle control
ST165 turbo 4WD
Gary ST165
Postby WarTowels » Thu Feb 11, 2010 3:49 am
^ Thank you for the pic.
Truly pics are worth 1000 words.
-Towels
2003 S2000
1985 300TD
WarTowels
Gold GTfour God
