3SGE intake manifold on a 3SGTE??
Re: 3SGE intake manifold on a 3SGTE??
Postby xander279 » Mon Feb 15, 2010 4:41 pm
there is a guy selling his gt-four that lives in mobile alabama (its in the ads section), and he has one, but he planned on selling it with the car, but maybe you can convince him to sell it to you... he also has a FMIC kit too that fits that manafold too. it would be a nice little project to do a Intake Manifold/ Intercooler conversion.
2013 Hyundai Genesis Coupe 2.0T
1992 Toyota Celica All-Trac Turbo
xander279
Postby eric thompson » Tue Feb 16, 2010 2:47 am
Gary ST165 wrote:This ST162 3sge manifold was modified for use with the ST185 TB and factory idle control
why do the runners on your manifold look so different from the runners on my 88 celica gts 3sge? does your manifold have 8 ports or 4?
ST165-PARTS-RED
NEED ONE MORE FOR STREET:)
https://www.youtube.com/watch?v=w-RCuV_Hmqk (ITS miata 6spd,4.78 rear, shitloads of fun!! multiple wins and track records in 2014)
eric thompson
Images: 6
Postby MWP » Tue Feb 16, 2010 3:49 am
That looks like a non-TVIS manifold...
I thought non-TVIS manifolds couldnt be used?
Postby Gary ST165 » Tue Feb 16, 2010 10:00 am
I have posted these pictures before on other threads :smokes:
This is the donor vehicle: UK ST162 with 3sge & TVIS
more pics of the manifold and being mocked up on an ST185 cylinder head:
ST165 turbo 4WD
Gary ST165
Postby MXP_57 » Tue Feb 16, 2010 12:17 pm
Is there any 3sge manifold without tvis ?
Also i have a block of plate for the idle valve. Would i still able to bolt it to the 3sge manifold?
Cheers
CEIKA Demo car 1987 ST165 JDM 1000kg/700hp http://ceikaperformance.com
MXP_57
Postby TRDcelica90 » Thu Feb 18, 2010 8:57 pm
ive heard there are both TVIS and non TVIS 3sges so yeh you should be able to get one. wouldnt have a clue if it would bolt up or not though.
1990 Toyota Celica GT-FOUR RC Now with the power of a Garrett GT30!!
1987 Toyota Celica GT-Four ST165 Rally car in the making..
TRDcelica90
Postby TRDcelica90 » Thu Feb 18, 2010 9:07 pm
also any1 just bolt up the 3sge throttle body and use our very long throttle cables??
cheers
TRDcelica90
Postby DudeMan » Thu Feb 18, 2010 10:46 pm
Mafix recommended using the GTE throttle body. Though his is a 165 and mine is a 185 I'm not sure if there's any differences.
Stock throttle cable is used too I assume.
I should maybe go pick one of these up tomorrow.
-Chase
1990 4Runner SR5
1990 Celica GT-Four
DudeMan
Postby MXP_57 » Fri Feb 19, 2010 8:56 pm
Also, does the 3sge manifold has a plug for the IAT ??
MXP_57
Postby bccentaur3 » Fri Feb 19, 2010 10:02 pm
Just get rid of the CSI and make a plate to mount the IAT... Thats what I'm doing with the honda ecu conversion
bccentaur3
Postby DudeMan » Fri Feb 19, 2010 10:02 pm
Whats IAT?
-Chase
1990 4Runner SR5
1990 Celica GT-Four
DudeMan
Postby trd-at » Fri Feb 19, 2010 11:20 pm
intake air temperature.
trd-at
Postby TRDcelica90 » Thu Feb 25, 2010 12:01 am
So in a nutshell the only problem is you need to modify it to fit the IAT.
But how do you do it??
TRDcelica90
Postby MWP » Thu Feb 25, 2010 3:23 am
Ermmm.... the IAT is in the AFM.
Only reason you need an IAT in the inlet manifold is if your using an aftermarket ECU.
Postby MXP_57 » Thu Feb 25, 2010 10:27 pm
Actually i was talking about the Manifold air temperature. (MAT?)
jdm st165 and st205 both have a manifold air temperature sensor and the iat in the afm for the st165 and in the airbox for st205 but the iat doesn't affect the tunning maps as much as the MAT.
I'm running the st205 ecu and i have a jdm st165 so i'll need to modify the cold start injector maybe to bolt the MAT sensor.
MXP_57
