3SGE intake manifold on a 3SGTE??
Re: 3SGE intake manifold on a 3SGTE??
Postby MXP_57 » Mon Jul 05, 2010 11:45 am
That's a 3sfe manifold, it won't fit.
CEIKA Demo car 1987 ST165 JDM 1000kg/700hp http://ceikaperformance.com
MXP_57
Postby WarTowels » Mon Jul 05, 2010 11:30 pm
^Good call. link removed
2003 S2000
1985 300TD
WarTowels
Gold GTfour God
Postby DudeMan » Thu Jul 14, 2011 2:30 pm
So what did you guys do with the hard lines that bolt to the back of the stock manifold?
There's two lines which go to the power steering pump on the passenger side and then a bunch of vacuum lines and possibly one coolant line on the driver side.
Did you guys just run longer vacuum hoses and not use the hardlines?
-Chase
1990 4Runner SR5
1990 Celica GT-Four
DudeMan
Postby trd-at » Thu Jul 14, 2011 4:50 pm
Yeah i just ran new vacuum lines since the vacuum ports are in different locations. No big deal at all
trd-at
Postby DudeMan » Fri Jul 15, 2011 12:10 am
GTE throttle body also hits the engine hoist hook, I assume you simply remove it once the engine is in the car.
There's a large vacuum or coolant hard line attached to the hook, anyone know what its for so I can bypass it?
I can grab a pic if it helps.
Oh yeah and does removing the CSI cause a cell?
-Chase
1990 4Runner SR5
1990 Celica GT-Four
DudeMan
Postby Mafix » Mon Jul 18, 2011 1:42 pm
not to my knowledge
Postby DudeMan » Mon Aug 15, 2011 6:13 pm
Has anyone retained cruise control after installing one of these on a 185?
The CC unit is located directly in front of the throttle body, obviously a problem.
And since the cable from the firewall is so short I'm not left with a lot of options for moving it, without further modifications..
Is it possible to squeeze a 2.5" pipe beside it? Maybe bend the bracket a bit?
-Chase
1990 4Runner SR5
1990 Celica GT-Four
DudeMan
Postby trd-at » Thu Aug 18, 2011 12:16 pm
You can go to a local yard and try to source a cable that is longer from another toyota and that should work. I used a shorter throttle cable to my throttle body from a 96 celica with a 5sfe and it functions great, needed to make a cable bracket though, no big deal
trd-at
Postby l0ch0w » Fri Aug 19, 2011 3:09 am
BTW, a note, its probably been brought up here, but for those of you running a gen 3 motor, the side feed option comes from the gen 4 caldina...
Andrew
1991 Red Alltrac
l0ch0w
Postby DudeMan » Fri Aug 19, 2011 3:44 am
I'm going to attempt to keep the CC in the stock location and squeeze the pipe beside it..
I was looking at it the other day and I think it might work. Won't know until I try though.
-Chase
1990 4Runner SR5
1990 Celica GT-Four
DudeMan
Postby loudstealthGT-Four » Sat Dec 10, 2011 8:41 am
THREAD REVIVAL 8)
Finally got round to finding a manifold and fitting it up came out really well, and looks waaaay better :D :D
just waiting for my CT20b to arrive so I can test it out.
loudstealthGT-Four
Postby mixer72 » Wed Dec 21, 2011 7:15 pm
some geat installs going on :) just got my self 1 of these side feed manifold :) has any 1 see what powre gains you get? and allso is it right that i can just block the air bypass screw at the top? will the engine still idle ok?
mixer72
Postby loudstealthGT-Four » Thu Dec 22, 2011 5:01 am
mixer72 wrote:some geat installs going on :) just got my self 1 of these side feed manifold :) has any 1 see what powre gains you get? and allso is it right that i can just block the air bypass screw at the top? will the engine still idle ok?
i've just bolted the 3sgte throttle body on with the 3sgte TB gasket and it seals fine
loudstealthGT-Four
Postby mixer72 » Thu Dec 22, 2011 5:06 pm
cool just what i wanted to here :)
the big build
viewtopic.php?f=44&t=34183
mixer72
Postby klue » Thu Dec 22, 2011 7:26 pm
Here is mine
Check out more pics on my build thread
http://www.alltrac.net/phpBB2/viewtopic.php?f=44&t=42636
Users browsing this forum: Bing [Bot] and 6 guests
