93celiconvertible
New member
i currently just purchased a jdm 3sgte for a 90-93 st185 from japandomesticmotor.com and ive been thinking bout what im going to do with the pressure plate. currently i have the 5sfe motor with the s53 transmission. the clutch kit i have on right now is centerforce dual friction clutch and pressure plate for the 5sfe. im going to be using the 5sfe centerforce clutch that i have on there right now but i dont know if i should buy the centerforce 3sgte pressure plate or just keep the stock plate that im receiving with the motor. should i purchase the 3sgte pressure plate from centerforce or keep the oem plate? whats the difference with the pressure plates and if its worth buying a new one from centerforce. thanks for the suggestions.
bong
bong
