how do you clock a turbo for 165
Postby saved_1992 » Tue Aug 17, 2004 2:12 pm
want to know how to clock a turbo down
any help appreciated
mike
omaha,ne
1988 a driver (RED) sold
1992 the keeper (RED)
1993 sold to 2of81 (RED)
saved_1992
Postby alltrac.net » Tue Aug 17, 2004 5:11 pm
If you are just changing the compressor housing, you can use snap ring pliers on the big c-clip and turn the housing. The wastegate is bolted to the housing, so you have to remove it first. If you clock the housing farther down, there will no longer be a place for the wastegate to mount, so you must fab something up.
ST165, then ST165, then ST185, then ST165.
Yes I've been there.
alltrac.net
Site Admin
Postby saved_1992 » Tue Aug 17, 2004 10:27 pm
thanks robert i will try that
mike
omaha,ne
saved_1992
