Quiet performance muffler?
Postby pg » Thu Apr 14, 2011 10:14 pm
Any suggestion on what type or brand of muffler you think reduces exhaust noise the best on a 3 inch system?
90 ST185 SB46 powered
[img]http://img87.imageshack.us/img87/8274/gtfour.jpg[/img]
pg
Re: Quiet performance muffler?
Postby jonnyboygt4 » Thu Apr 14, 2011 11:45 pm
haha is that even possible...my 3 inch is loud as hell lol...
quiet= restriction....kinda defeating the purpose of a 3 inch exhaust.. :shrug:
91 JDM ST185
"just a little 4-banger"
jonnyboygt4
Postby yauman » Fri Apr 15, 2011 12:07 am
HKS silent hi power
yauman
Postby lumbercis » Fri Apr 15, 2011 12:46 pm
I'd say HKS Hi-power as well. I had the old non-silent version and it wasn't bad at all. Although I was running a stock midpipe at the time.
The silent Hi-power should be even quieter.
J.
Caldina powered...
lumbercis
Postby phattyduck » Fri Apr 15, 2011 3:51 pm
The secret to quiet with flow is volume (lots of muffler volume). If you are doing custom, go for a 3" muffler in the normal location, another 3" muffler in the rear resonator spot and as big of a resonator in secondary cat location as you can fit. Offset in / center out would quiet it down more than center-in / center-out. A turbo car with three perforated (not louvered) straight through mufflers should be pretty quiet but still flow very well. I have always been partial to magnaflow mufflers when doing custom stuff.
'99 4Runner SR5 4WD 5VZ-FE
phattyduck
Postby WarTowels » Fri Apr 15, 2011 11:08 pm
I didn't find the HKS Silent Hi-Power to be quiet at all. The complete opposite even.
With 3" everything, it's super loud.
The quietest exhaust for the All-trac I've seen is probably the SSAC Twip Tip.
-Towels
2003 S2000
1985 300TD
WarTowels
Gold GTfour God
Postby gtfourever » Mon Apr 18, 2011 3:42 am
I agree HKS Silent yeah not very silent.
gtfourever
Postby Simba » Mon Apr 18, 2011 11:37 pm
Flowmaster Hushpower mufflers work pretty well, I've used them in a number of applications where noise level was an issue. 2-3 hp difference over an open can or straight pipe.
Lots of fast, loud things.
Simba
Postby pg » Sun Apr 24, 2011 5:59 pm
Were they the PRO Series or the DBx Series? Which one would be better for my application do you think?
pg
Postby CMS-GT4 » Sun Apr 24, 2011 7:39 pm
I wonder if we could get SSA to make their twin tip again. That is sort of the route I am leaning.
Postby jonnyboygt4 » Mon Apr 25, 2011 12:13 pm
CMS-GT4 wrote:I wonder if we could get SSA to make their twin tip again. That is sort of the route I am leaning.
check this out!
http://cgi.ebay.ca/Toyota-Celica-GT4-ST ... 3f09309779
91 JDM ST185
jonnyboygt4
Postby CMS-GT4 » Mon Apr 25, 2011 3:12 pm
Thanks for posting. Shame they want too much for it. I should have bought the cheap SSA when I could. My sard is only 2.5 but its loud as hell. I might just buy that cheap 205 system and modify it to fit. I'll start by getting a high flow cat first, and then start reducing sound from there.
Postby Simba » Tue Apr 26, 2011 12:23 am
pg wrote:Were they the PRO Series or the DBx Series? Which one would be better for my application do you think?
Pro.
Simba
Postby Mitsuslider » Wed May 04, 2011 3:18 am
Im only running a 2.5" mongoose system with 3" downpipe, but its quiet as hell.
Mitsuslider: "I broke your candy!"
Mitsuslider
Postby 92 All-Trac » Wed May 04, 2011 11:26 pm
I'd suggest multiple mufflers as well if you're wanting quiet while maintaining good flow. Just gotta fork out the $$. I have a 3" Magnaflow on mine, pretty damn loud...I plan on placing a straight-through muffler somewhere in-line eventually to quiet it down.
Josh
1992 ST185
92 All-Trac
Users browsing this forum: Yahoo [Bot] and 2 guests
