donnyavery
New member
ok well i had a idea and was wondering what yous think and any opinions you might have i have been looking for a cheap way to improve turbo response of a cheap mbc or this way a cheap brass hard ware store valve would work too but any one who has used one knows the it will cause you system to build more boost but at a slower rate and a wastegate with no boost controller will start bleeding boost off before you make max boost (the cracking point of the wg) so i was thinking if i take the stock tvsv (sens every one bypasses it to make more boost) and wiring it to a boost switch ebay for like 20$ like the one that comes with the water/meth kits so you open it at say 3 pounds of boost before your max setting so that way the turbo dont have to over come the boost leak(mbc) to build max boost i think this would improve response a lot i mocked up a the tvsv so you can see what i mean the hose at the top ov the pic would be from the ic piping and the hose at the bottom of the pic would go to wastgate and the one to the left would bleed to the air
