fresh rebuild on 1990 all trac. factory ct26 turbo, factory wastegate, factory exhaust manifold, aftermarket downpipe. no codes for running rich/lean, but pulling codes for 34 and code 35. pulls hard in first gear, but in second hits fuel cut. code 35 is for open/short in turbo pressure sensor, could it be possibly causing the code 34 as well? i've already checked and there is 5V going to the pressure sensor, telling me the wiring to the sensor is ok, so im heading towards possible bad pressure sensor? any input would be great. thanks.
