aus jd 2703
New member
It blocks incoming surface area of the radiator. I did some rough calc and assuming u have airflow to the whole radiator core which is impossible as the intake area on the bumper isn't the large the radiator will flow 10500cfm this is likely to be a lot less as it depends largely on the intake area on the bumper. I'll measure tonight and check but I'm suspecting good fans will be as good at speeds lower than 60kph. As for pushing vs pulling I have always been told pulling is better as you have a large intake surface area
