Terracar":d6fqy82v said:I paid $1100 for mine - DP back full 3" mandrel bent stainless. This has a cat pipe and a test pipe (see the group buy below). I went with an under axle for the cat back. To this day I have yet to scrape the underaxle portion. I live in the boonies so the road to my house is uneven and just gravel and never had a problem, nor with speed bumps have I had an issue. The shop I used did a great job and it sits nice anc close so it doesn't hang down.
-Terracar
underscore":d6fqy82v said:I paid something like $1200 for a full exhaust and custom seat bracket, $150 of which was the muffler, and $200 was for a flex pipe, this was from the downpipe back. The rear axle is the only issue, apart from that it's almost a perfectly straight pipe (just a couple bends at the front, then straaaaaight, then the rear axle.)
Terracar":3e7jo354 said:I paid $1100 for mine - DP back full 3" mandrel bent stainless. This has a cat pipe and a test pipe (see the group buy below). I went with an under axle for the cat back. To this day I have yet to scrape the underaxle portion. I live in the boonies so the road to my house is uneven and just gravel and never had a problem, nor with speed bumps have I had an issue. The shop I used did a great job and it sits nice anc close so it doesn't hang down.
-Terracar
Half price pretty much, depending on what model varex you want.underscore":37mskvqw said:that's actually fairly cheap for a muffler, no?
awolo":2zvh4qb6 said:1k+ for an exhaust system??
That's absolutely crazy.
