Those who have built 2.3L engines
Postby dragstang86 » Tue Jan 31, 2012 9:42 pm
Has anybody built a 2.3 with off the shelf pistons and just machined the top of the piston the .125 or so that the stroke has gained from the offset grinding of the crank? I would think the piston would have plenty of material to take it off without hurting anything.
92 All trac
90 Mustang drag radial car in the 7's on 275's
86 Mustang Coupe tube chassis/stretched/fiberglass body
Autofab Dragsters 7's on motor, 6's on spray
90 Mustang Coupe
Ford Excursion Ltd 7.3
99 Civic Ex beater
Yamaha R1 Raven
dragstang86
Re: Those who have built 2.3L engines
Postby gearhead313 » Wed Feb 01, 2012 12:09 am
I've machined domes off of pistons to adjust compression height, but not to physically lower the height of the piston. I would never try that, less material in a volatile environment is no good! If you have an 'out of the hole' situation, then either thick head gasket it or stack gaskets.
ST165 counter:
#2597 - fail
#3193 - fail
#xxxx - sold
#4598 - win (for now)
gearhead313
Postby dragstang86 » Wed Feb 01, 2012 12:19 am
I have done the same. I figured it would essentially be the same as milling a dish into a flat top piston?
92 All trac
90 Mustang Coupe
99 Civic Ex beater
Yamaha R1 Raven
dragstang86
Postby gearhead313 » Wed Feb 01, 2012 12:27 am
10-4... I guess if there is anyone else with first hand experience on this particular cubic inch build, they can share more accurate accounts. I, though, wouldnt try it! Does it require a piston thats not readily available? I unfortunately dont know that much on getting 2.3l out of the 3s...
ST165 counter:
#2597 - fail
#3193 - fail
#xxxx - sold
gearhead313
Postby dragstang86 » Wed Feb 01, 2012 12:37 am
It would require a custom piston which would probably end up being twice as much as the off the shelf pistons. The off the shelf stuff is for use with standard 2.2 stroke. If I offset ground the crank I could get an additional 4mm of stroke so the off the shelf piston would be out of the hole that 4mm. So its either machine the piston top or have a custom made piston with the pin location 4mm higher in the piston. I don't think it's work that much to me if I have to spend double on a set of pistons on top of the additional machine work to offset grind it. If I can just machine a shelf set myself then I would consider it.
92 All trac
90 Mustang Coupe
99 Civic Ex beater
Yamaha R1 Raven
dragstang86
Postby Hic » Wed Feb 01, 2012 9:29 am
dragstang86 wrote:It would require a custom piston which would probably end up being twice as much as the off the shelf pistons. The off the shelf stuff is for use with standard 2.2 stroke. If I offset ground the crank I could get an additional 4mm of stroke so the off the shelf piston would be out of the hole that 4mm. So its either machine the piston top or have a custom made piston with the pin location 4mm higher in the piston. I don't think it's work that much to me if I have to spend double on a set of pistons on top of the additional machine work to offset grind it. If I can just machine a shelf set myself then I would consider it.
Check your calculation. You are very wrong.
My engine is 2.284cc (2.3). 87.5 * 95mm. And I know EXACTLY what to do ;)
Hic
Postby dragstang86 » Wed Feb 01, 2012 1:26 pm
Do you care to share? And I am just doing this off the top of my head, but if you put piston that has a pin location for a 91mm stroke crank in it, that would have a 0 deck height with a 95 mm crank, than that's 4mm out of the hole.
92 All trac
90 Mustang Coupe
99 Civic Ex beater
Yamaha R1 Raven
dragstang86
Postby l0ch0w » Wed Feb 01, 2012 3:43 pm
Dont know why you would want to run 2.3L...
You would have decent midrange, but the inherent balancing problems of a stroker motor wouldnt be very fun and you would start running into issue at higher RPM. Oversquare engines like RPMs alot more than strokers do...
Pat is making more power and hitting higher revs with his 2.1L Destroked oversquare 5s block than he did on his 2.2L stroker...
Just sayin...
Andrew
1991 Red Alltrac
l0ch0w
Postby gearhead313 » Wed Feb 01, 2012 5:35 pm
A few years back i built a prelude motor with custom sleeves and pistons... i want to say the pistons were out of a vega??? I would just find a legit machine shop and pick their brain. My guy was UNbelievable with stuff like that.
I wouldnt worry about revving it with that rod/stroke.. sure a 2.1l destroke is better, but how high you NEED to rev to put a turbo in operating range is a different story. 500hp is no biggie and more cubes gets her going sooner without changing much redline power.
ST165 counter:
#2597 - fail
#3193 - fail
#xxxx - sold
gearhead313
Postby Hic » Wed Feb 01, 2012 5:43 pm
l0ch0w wrote:Dont know why you would want to run 2.3L...
Just sayin...
Not decent, but really strong. It revs 8500 no sweat, tested in mr2. For normal engine....more than good. Easy and nice to drive. For pat's application, yes, long rod and short piston is fine.
Hic
Postby WarTowels » Wed Feb 01, 2012 6:17 pm
My engine is only 2183cc :cry:
1993 All-trac
2003 S2000
WarTowels
Gold GTfour God
Postby dragstang86 » Wed Feb 01, 2012 6:49 pm
I wouldn't be scared to rev a 95 mm stroke engine. Hell I rev my 4.600 bore (~117mm) 4.500 stroke (~114mm) to 8500+rpm week in and week out and they are making 1200+ hp N/A with a 500-600 hit of nitrous on top of that.
95mm is about 3.75 inches which is the stroke of a standard 400 small block Chevy which is the crank that is used in all the 383's out there are ton's of people who wing those things way up there with 8 rods and pistons swinging from it.
So I don't see how, if these cranks are as strong as people claim they are, 8500 would hurt it at 95mm.
92 All trac
90 Mustang Coupe
99 Civic Ex beater
Yamaha R1 Raven
dragstang86
Postby Hic » Wed Feb 01, 2012 7:51 pm
It is not the stroke, it is a rod/stroke ratio.
Rod is too short.
Ultimate engine would be 2.1L, with long rod, 86mm stroke and short piston.
Like 143 rod and 30 piston.
Hic
Postby roo » Sat Jul 21, 2012 11:19 am
Have any of you guys tried this?
http://www.briancrower.com/makes/toyota ... oker.shtml
2.16L with a 91mm stroke and 87mm bore
roo
Postby RedCelicaTRD » Thu Aug 02, 2012 2:56 am
Wha? When did roo show back up?
And also, I know a a regular 2.2 stroker can rev to 9k no problem.
2005 WRX STi, Again
2011 WRX Wagon
