Mishimoto st185
Re: Mishimoto st185
Postby brutekiller787 » Fri Jul 26, 2013 4:12 pm
If its anything similar to ASI the 185 would be slightly thicker (52mm vs 46mm) and it does not have the water cooler outlet next to the top main hose. Otherwise they are the same
brutekiller787
Re: Mishimoto st185
Postby GT4_DRED » Fri Jul 26, 2013 7:22 pm
brutekiller787 wrote:If its anything similar to ASI the 185 would be slightly thicker (52mm vs 46mm) and it does not have the water cooler outlet next to the top main hose. Otherwise they are the same
Good! I don't use the water outlet anyway. Thanks!
'88 ST165 - project "Rahtid"
'91 MR2
GT4_DRED
Re: Mishimoto st185
Postby klue » Fri Jul 26, 2013 9:00 pm
are you 100% sure?
honest question
Re: Mishimoto st185
Postby brutekiller787 » Sat Jul 27, 2013 1:56 am
Let me look at some pictures. I'll edit soon
Edit: Yup, Google images says I'm right
brutekiller787
Re: Mishimoto st185
Postby mike325ci » Sat Aug 03, 2013 9:28 pm
FYI, I have a write-up on my Mishimoto radiator installation on an ST185 on my "Project Car" thread with photos here:
viewtopic.php?f=44&t=22973&p=446018#p446018
In short, it was a very simple and almost perfect swap from stock and fits very well. No comment on performance yet as I need to do a track or autcross day to see (sorry, no true water temp gauge).
NYC, NY, USA
mike325ci
Re: Mishimoto st185
Postby Droptop93 » Tue Sep 10, 2013 3:23 am
Can I reuse my radiator cap with this radiator? I have a genuine TRD cap. Or do I have to use their's?
Also anyone running the mishmoto fans?
Droptop93
Re: Mishimoto st185
Postby FC Zach » Tue Sep 10, 2013 5:00 am
I'm not sure about the cap but I could try later.
I'm using one of their slim fans and it works great for my application.
1992 Toyota Celica AllTrac
1987 Mazda RX7 Sport
FC Zach
Images: 9
Re: Mishimoto st185
Postby Droptop93 » Tue Sep 10, 2013 5:54 am
Thank you.
Droptop93
Re: Mishimoto st185
Postby FC Zach » Tue Sep 10, 2013 6:10 am
I'll try swapping the caps in the am when I'm off, if I remember and I'll let you know.
FC Zach
Images: 9
Re: Mishimoto st185
Postby Droptop93 » Tue Sep 10, 2013 1:11 pm
Very cool. Thanks again
Droptop93
Re: Mishimoto st185
Postby FC Zach » Tue Sep 10, 2013 1:32 pm
Doesn't even look close.
OEM right, Mishimoto left
FC Zach
Images: 9
Re: Mishimoto st185
Postby gtfourdreams » Tue Sep 10, 2013 1:36 pm
i have the mishimoto on my ST185 with standard green coolant and an aftermarket fan. (just a single one on the driverside of the rad). The last few track events I did were mostly 35-50mph and 90% in top of 2nd gear. in 80 degree weather and a hot track, I was only able to drive for 10-15 minutes before the temp gauge started going up (slowly). I think the problem is with overall airflow at those low speeds. The stock alltrac bumper is much too restrictive. I plan to get an ST185RC bumper and better dual fans to hopefully address the issue. I've done some hard driving at faster speeds (55-90mph) without any issues. hope that helps you guys.
Red 86 Supra MA60
Grey 88 Alltrac ST165
Black 92 Alltrac ST185
Red 93 MR2 SW20
Minneapolis, MN
gtfourdreams
Re: Mishimoto st185
Postby gtfourdreams » Tue Sep 10, 2013 1:37 pm
also I'm running the Mishimoto cap if anybody cares. I have a Blitz one somewhere I could try as well.
Red 86 Supra MA60
Red 93 MR2 SW20
Minneapolis, MN
gtfourdreams
Re: Mishimoto st185
Postby Droptop93 » Tue Sep 10, 2013 4:54 pm
FC Zach wrote:Doesn't even look close.
Bummer but thank you
Droptop93
Re: Mishimoto st185
Postby underscore » Tue Sep 10, 2013 8:28 pm
my AutoPwr rad uses a Mishimoto cap because an OEM one wouldn't fit, so unless Mishimoto has a few different sizes of cap, anything that fit OEM won't work on a Mishi.
