Mishimoto st185
Re: Mishimoto st185
Postby kn0wledge185 » Thu Jan 22, 2015 12:09 am
The hose was sitting on the block
kn0wledge185
Re: Mishimoto st185
Postby klue » Thu Jan 22, 2015 3:45 am
this filler neck leaking was a common problem. I have welded a few of them on different models including the alltrac for this same reason. They have since revised the design, the caps are also improved. I use the 18psi cap with no issues.
They now also have a high flow fan which is good for our hot running cars. I have not tried it out but the testing seems good. They have come a long way in terms of product quality over the past few years.
If anyone is interested in making a purchase or needs help getting there rad replaced please contact me, xiiimotorsports is an authorized vendor here and I deal with mishimoto regularly.
Re: Mishimoto st185
Postby alltracman78 » Fri Jan 23, 2015 12:14 am
CSAlltrac wrote:I'm using the stock fan, it bolts right on with little effort.
Do you have any pictures of that? And where did you buy yours from? The Mishimoto I got [Amazon] wasn't even close. The mounting holes didn't line up and they held the fan too far away from the radiator.
Re: Mishimoto st185
Postby klue » Fri Jan 23, 2015 1:06 am
You got an older model, this is something else that has been revised. Slim fans FTW
Re: Mishimoto st185
Postby kn0wledge185 » Sat Jan 24, 2015 3:26 am
If the mod could delete my past post would be cool.... I thought it was my project post sorry
kn0wledge185
Re: Mishimoto st185
Postby alltracman78 » Sat Jan 24, 2015 4:55 pm
Interesting..... I just ordered it spring of 14; and I had direct contact with Mishimoto about the problem [they weren't very helpful].
I like my stock fan because i have an RC fan [more fan blades and a stronger motor] so I have better "performance" with stock reliability.
You're sure the current radiators will allow the fan to bolt right up? I wouldn't mind a better radiator.
Re: Mishimoto st185
Postby klue » Sun Jan 25, 2015 1:54 am
Maybe I am incorrect but are the fans different bolt pattern? I haven't had anyone say the fans dont fit, and I sell quite a few of the rads.
Re: Mishimoto st185
Postby CSAlltrac » Mon Aug 10, 2015 1:25 am
When I say they fit with little effort, I view it as little effort. All I did was drill new holes and cut off a portion of the bottom. The bottom does not bolt directly to the radiator but instead I used a spring to apply enough pressure that holds the fan to the radiator. Some may not like the "cleanliness" of this method but I have been running this for years now with zero issuesImageImageImage
