Block Girdle brace????
Postby monkracing29 » Mon Feb 27, 2012 2:55 pm
has anyone every seen this this seen i think is kinda crazy looking i was on 3senginebuilders website and found this picture how exactly does it work it kind of looks like the main bearings are gone?? or does it have a bearing inside of it??
Monk
monkracing29
Re: Block Girdle brace????
Postby klue » Mon Feb 27, 2012 3:14 pm
I've got one. The main caps are still there. You replace the main cap bolts with arp studs, then put the brace on and tighten the nuts to the brace, unifying the whole assembly.
Postby monkracing29 » Mon Feb 27, 2012 3:54 pm
where do you get them from they looks like it would make it stronger
Monk
monkracing29
Postby klue » Mon Feb 27, 2012 8:08 pm
sent you a PM very few of these left
Postby underscore » Tue Feb 28, 2012 5:18 am
Is there a specific weakness this takes care of? It's probably overkill for my needs but that sounds pretty badass.
Postby klue » Tue Feb 28, 2012 1:55 pm
its a general weakness of the block. If you look at other high output engines like the 4g63, the mains are grouped together for strength. Some engines have this feature build right into the casting
Postby Mafix » Wed Feb 29, 2012 12:54 am
personally i think this is overkill, but to each his own!
Postby krazy2 » Wed Feb 29, 2012 2:01 am
Alloy racing components builds girdles and just about anything you need. Based in Australia. These were built for a friend of mine.
Girdle
Pan
Mains
and even throttle bodies and cam gears.
1988 Alltrac Celica 205 with extra's
1986 Supercharged Mr2 lots of extras
1991 Supercharged MR2 V6 lots of TRD extra's
1990 4runner soon to be Lexus V8
krazy2
Postby toayoztan » Wed Feb 29, 2012 2:21 am
Mafix wrote:personally i think this is overkill, but to each his own!
Ditto.
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
1977 Celica GT Liftback
2015 Grom
1977 GL1000
toayoztan
Postby krazy2 » Wed Feb 29, 2012 2:37 am
To each his own is true, it mainly depends on the horse power ur trying to achive and what ur using the power for.
krazy2
Postby klue » Wed Feb 29, 2012 3:30 am
pretty sweet shit there krazy2
Im tracking so the point is to over kill
block needs all the strength it can get, keeping in mind with solid mounts, hard ass suspension, and r comp tires we are dealing with more than just reciprocating stress, but actual g forces trying to rip the block in half.
Postby underscore » Wed Feb 29, 2012 3:47 am
I'm only aiming for 300AWHP & maximum handling with solid mounts for everything for this build, but my car will be extensively autocrossed, King of the Hill'd and dragged, as well as some real track time in the future.
For those needs, do you guys think this is overkill?
Postby klue » Wed Feb 29, 2012 3:30 pm
Don;t base your decision on what we think.
For less than 200 bucks I think you could spend your money on worse parts...
Keep in mind by using this block girdle your adding oil capacity.
Postby Klas » Wed Feb 29, 2012 5:22 pm
Don´t forget that you will have to weld the oilpan if you use a girdle. (to clear the rear main studs)
You also will have to make an extension for the oil pickup. (don´t remember if it nessesery, I did it anyway).
1/4 in 12.577s 176km/h so far
If you can turn, you drive to slow!
Now on youtube!
http://www.youtube.com/watch?v=hSD6LlwS830
Klas
Postby aus jd 2703 » Wed Feb 29, 2012 7:33 pm
How much are we talking for that girdle with maincaps?
aus jd 2703
