Block Girdle brace????
Re: Block Girdle brace????
Postby klue » Wed Feb 29, 2012 9:05 pm
Klas wrote:Don´t forget that you will have to weld the oilpan if you use a girdle. (to clear the rear main studs)
You also will have to make an extension for the oil pickup. (don´t remember if it nessesery, I did it anyway).
good point, the girdle I have came with a oil pick up extension. And yes unless you have a moroso pan you need to kick out for the studs closest to the rear main seal
Postby krazy2 » Wed Feb 29, 2012 9:56 pm
If your talking about the pics of my friends girdle I will have to ask him. He works nites this week.
1988 Alltrac Celica 205 with extra's
1986 Supercharged Mr2 lots of extras
1991 Supercharged MR2 V6 lots of TRD extra's
1990 4runner soon to be Lexus V8
krazy2
Postby underscore » Thu Mar 01, 2012 6:09 am
klue wrote:Don;t base your decision on what we think.
For less than 200 bucks I think you could spend your money on worse parts...
Keep in mind by using this block girdle your adding oil capacity.
$200 doesn't seem too bad, but then from the sounds of it I need the Moroso pan + customizing to clear the brace. I'm asking you guys because I still have very little experience when it comes to performance vehicles and the STxx5 in general.
Postby klue » Thu Mar 01, 2012 3:54 pm
you dont need a moroso pan. I've modified lots of stock oil pans to clear the studs. Basically the section you cut out you can flip it around and weld it back in to have enough clearance.
Postby salutmecos » Thu Mar 01, 2012 4:28 pm
salutmecos
Postby YerRandO » Mon Mar 12, 2012 2:27 am
salutmecos wrote:3SGTE Block Girdle 120.00$
http://twosrus.com/catalog/product_info ... cts_id=297
Not a complete kit, read the description you would have to fabricate some parts it no longer comes with.
-James
YerRandO
Postby gunt » Fri Jan 30, 2015 9:44 pm
Hi
i have been trying to find that girdle , can you post a link , if you get a chance
gunt
Postby klue » Sat Jan 31, 2015 6:08 am
gunt wrote:Hi
Ive still got the design for it, with oil pick up extension
Postby gunt » Sun Feb 01, 2015 8:53 am
thanks but kinda need one fast off a shelf
cheers
gunt
Postby klue » Sun Feb 01, 2015 5:01 pm
gunt wrote:thanks but kinda need one fast off a shelf
cheers
I don't think you can get them off the shelf anymore. Try used adds
Postby gunt » Sun Feb 01, 2015 8:33 pm
thanks i would have used one if to hand but when i seen the pics i thought there might be a chance , ill check it out on the used ,
Cheers
gunt
