V6 Celica
V6 Celica
Postby alexinvancouver » Thu Mar 01, 2012 6:10 pm
doing some search yesterday i came across this tread where a guy in Australia did a V6 swap.
the engine came from 96 Camry and he turbocharged it
it was 2WD Celica though
there's also V8 Celica as well
Wonder if any one in North America attempted doing V6 swap on alltrac?
I personally like n/a engines for low end torque
...and giving a boost to 3L V6... =o)
http://www.toyotacelicas.com/forums/94-fifth-generation/45525-my-v6-5th-gen-conversion.html
1990 Celica Alltrac
2001 Impreza RS Stage Rally car
2006 Honda Ridgeline
2014 Subaru Impreza
alexinvancouver
Re: V6 Celica
Postby mx6er2587 » Thu Mar 01, 2012 6:38 pm
definitely a doable project. The Mr2 guys swap the camry V6 in quite frequently. Most of the pertinant information would be the same between the two. You should check out mr2oc and read up on their swaps
mx6er2587
Re: V6 Celica
Postby CMS-GT4 » Thu Mar 01, 2012 6:41 pm
Already a UK member who did a v6 swap into an alltrac using a rav4 gearbox. Another member on the board is working with a newer v6 that should mate up to the alltrac transmission.
Re: V6 Celica
Postby monkey8oi » Thu Mar 01, 2012 7:39 pm
yup.. definitely doable... my friend darren owns the red mr2 with the v6 camry motor in it..
monkey8oi
Re: V6 Celica
Postby jonahs_3sgte » Thu Mar 01, 2012 7:49 pm
http://www.youtube.com/watch?v=V9W0xvFlWVQ
v6 twin turbo awd conversion on a 5th gen
1988 ST165...66,000 miles
2009 Corolla
1999 Ranger
jonahs_3sgte
Re: V6 Celica
Postby alexinvancouver » Thu Mar 01, 2012 10:43 pm
yep, i've watched that video
i admire those guys, but that project was done in high-end garage
and definitely tons of money spent on it.
mr2 won't do because it's not 4wd
newer v6 with original transmission sounds very appealing
...i got to do some more digging about it =o)
...hard to find the right tread through the "search" though =o)
1990 Celica Alltrac
2014 Subaru Impreza
alexinvancouver
Re: V6 Celica
Postby gearhead313 » Thu Mar 01, 2012 11:24 pm
Thats the first time i've seen that v6 awd TT 5th gen...
I'd beg to differ, that looks like a little garage with a bunch of smack offs like myself rigging stuff together...... i mean, props for doing it but eh... tune sounds bad, smokes on the upshift... not impressed.
ST165 counter:
#2597 - fail
#3193 - fail
#xxxx - sold
#4598 - sold to Canada eh
gearhead313
Re: V6 Celica
Postby MWP » Sun Mar 04, 2012 11:52 am
The guy in Aus used a 3VZ... wrong way to go IMHO.
The V6 to use is the 1MZ.
All alloy, so its about the same weight as the 3SGTE.
The xVZs are too heavy in an already front-heavy car.
Re: V6 Celica
Postby Hic » Sat Mar 10, 2012 8:01 pm
3vz is better engine, more
Robust.
Hic
Re: V6 Celica
Postby scottytohotty » Sat Mar 10, 2012 10:34 pm
Another v6 engine i have seen swapped into mr2/celica is the 2gr-fe and i tell you what my step dad has a 2grfe camry and that thing hauls a** it is honestly concerning how fast that camry is. I always love going to car events when i take the camry because i get to blow peoples mind's on the way :D
Black 1992 non sunroof st185 gt4
Teal 1992 st185 celica alltrac
scottytohotty
Re: V6 Celica
Postby Hotrodhendrix » Wed Mar 14, 2012 2:35 pm
Im to lazy for this stuff.. 4 banger it is :P
Re: V6 Celica
Postby Smaay » Wed Mar 21, 2012 4:04 pm
the 2GR is the optimum choice, but again its a wiring nightmare. its a DBW car so there is no throttle cable. you have to use the electronic gas pedal.
A better V6 swap is the 1MZ since its still a cable throttle. Im actually building a 3MZ hybrid. 3.3L 3MZ with 1MZ heads and intake. so i can run it with the 1MZ ECU. but this is in my 6th gen Celica not All-Trac.
2001 Celica GT-S 2ZZ-GTE
90 Celica All-Trac 3S-GTE
97 Supra 2JZ-GTE
97 Celica GT 3MZ/1MZ hybrid
Smaay
Re: V6 Celica
Postby ALLensTRAC » Wed Mar 21, 2012 4:32 pm
Hotrodhendrix wrote:Im to lazy for this stuff.. 4 banger it is :P
AMEN!!!!
Allen
ALLensTRAC
Re: V6 Celica
Postby fibrewizard » Wed Sep 02, 2015 10:45 pm
The aussie Build was My build...
the Twin Turbo GT4 build as mentioned above, has been through many different iterations, and is now in the process of a mental build, and it was A st184 cut and converted to AWD, as gt4 celicas are extremely rare in USA.....so he made his own........
on that, my current build is gt4 with the same 3vzfe conversion that I did in my 184, however keeping it AWD and adding a turbo.....
the 3vzfe is so much more of a robust and compliant engine compared with the 1mz, 2gr, and has less issues with wiring and bottom end strength.......
weight gain in my st184 was only 56kg with the v6 installed and finished
cant wait to get into this gt4 build
started stripping the 184, and have a 185 shell here all ready to start
fibrewizard
Re: V6 Celica
Postby Cuttyman9 » Fri Jun 16, 2017 7:29 pm
Working on it in my soon to be grt184.
Used my 3D printer to prototype a pedal bracket, waiting on the machinist to make it for me from aluminum. Only requires covering the old hole for the cable and cutting an HVAC mounting arm.
Considered making that available if there's enough demand.
Doug did the wiring.
So far it's been very straight forward. I have 90 percent of the parts needed/mods to start the swap. Currently trying to get the car running so I can move onto the Z and then play some musical cars.
Got the motor for cheap and canned my 5sgte build (85 percent of the way through that sadly) so it only made sense.
From what I've seen they fit under the stock hood with minimal clearancing/hood spacers.
1992 Celica GT Hatch
1971 Cutlass
1967 Chevelle
1975 Trans Am
1966 C20 Long Bed
1999 F150
Cuttyman9
