For those who want a 2.5" downpipe for there ST165's...read
Postby jonahs_3sgte » Thu Mar 01, 2012 7:56 pm
I have been wanting to source a nice downpipe for my st165 with single scroll turbo
Contacted Aussie performance and they no longer make these
I have been in contact with a member on here who has contacted KO racing
They could make them for around $300 usd but the more who are interested the lower the price
If interested send me a message with interest and i will contact the member for a running total
Use your income tax for a good upgrade :)
1988 ST165...66,000 miles
2009 Corolla
1999 Ranger
jonahs_3sgte
Re: For those who want a 2.5" downpipe for there ST165's...r
Postby UtahSleeper » Fri Mar 02, 2012 4:11 pm
I will have to see where this is at in a month or so when I should have a running alltrac.
UtahSleeper
Postby JohnNK » Fri Mar 02, 2012 4:46 pm
I would be interested. Thanks.
JohnNK
Postby Anoo21 » Fri Mar 02, 2012 4:50 pm
Same here interested.
Anoo21
Postby ZeroDrift » Fri Mar 02, 2012 7:00 pm
If it fits a CT26 turbo I may be interested. What material?
Postby klue » Fri Mar 02, 2012 7:54 pm
Hi guys the downpipes are mild steel, and ceramic coated for rust and heat properties. Mild steel is more resistant to cracking, and if used correctly with their supplied support bracket you can have years of trouble free use. I use KO pipes exclusively on any CT based turbo, for my track applications and street.
They will fit the st165 CT26 on a gen 1 st165 this downpipes will be specific to the st165. Though we can get other set ups.
Postby jonahs_3sgte » Fri Mar 02, 2012 9:40 pm
^^well put lol
Have you heard from ko yet klue?
Zerodrift make sure your turbo is a gen 1 ct26...it will have 4 bolts for the downpipe
Klue I would be very interested in a spare o2 bung for wideband and additional bung for egt sensor
2009 Corolla
1999 Ranger
jonahs_3sgte
Postby ZeroDrift » Sat Mar 03, 2012 12:42 am
klue wrote:Hi guys the downpipes are mild steel, and ceramic coated for rust and heat properties. Mild steel is more resistant to cracking, and if used correctly with their supplied support bracket you can have years of trouble free use. I use KO pipes exclusively on any CT based turbo, for my track applications and street.
That sounds good. Any plans to have mounting points for stock heat shields?
jonahs_3sgte wrote:^^well put lol
Thanks for verifying that! I do have a spare gen 1 CT26 turbo then. Going to get it overhauled in the future and it would be nice to put on a new downpipe at the time of installation!
Postby klue » Sat Mar 03, 2012 2:39 am
Im sure we can get the bungs you need put in. I would like to have that specified on the list that we should start running. Have not heard back from Kris recently I will give him a call tomorrow
The stock heat sheilds do not mount to the turbo. The Cat downpipe has them to retain heat in the CAT, we do not need them, the ceramic coating serves this purpose much better
Postby jonahs_3sgte » Sat Mar 03, 2012 3:07 am
Jonahs_3sgte...downpipe, wideband bung and egt sensor bung
2009 Corolla
1999 Ranger
jonahs_3sgte
Postby ZeroDrift » Sun Mar 04, 2012 5:18 am
I would be interested in a downpipe with 2 oxygen sensor bungs. Ceramic coatings are nice, but something additional would be nice. At the very least some mounting brackets so I could build a heat shield in addition to the coating. Anything to reduce heat soak.
Postby klue » Sun Mar 04, 2012 4:38 pm
Spoke to Kris basically we need to get a number together for him to price out. Zerodrift You do not need any other heat shields besides the OEM one that bolts to the turbo and manifold not to the downpipes. The downpipe heat sheilds are not required. Also DO NOT heat wrap these pipes or any downpipe for that matter for it will void any type of warranty and lead to premature failure.
Making a list. Please let me know if corrections need to be made. IF your on the list this is your word people.
1. ZeroDrift - st165, , wideband o2
2. Jonah_3sgte - st165, EGT bung wideband o2
3. Anoo21 - st165
4. John NK - st165
Postby jonahs_3sgte » Sun Mar 04, 2012 8:15 pm
i'd like a wideband o2 bung and a egt
thanks
2009 Corolla
1999 Ranger
jonahs_3sgte
Postby klue » Sun Mar 04, 2012 8:56 pm
No problem they come standard with a wideband o2
Postby ZeroDrift » Mon Mar 05, 2012 2:25 pm
Are these going to be a bellmouth downpipe, or is this going to be a potential restriction to the waste gate by forcing the bypassed exhaust to have two 90° bends before joining with the rest of the downpipe?
