intercooler life line
Re: intercooler life line
Postby underscore » Wed May 09, 2012 4:39 pm
I'm guessing that a good way to tell when your intercooler is reaching it's limits would be an IAT sensor, because typically the stock setup is still good for near-stock applications. Because you basically want the smallest cooler for your power levels to reduce lag.
Mafix wrote:High flow water pumps and constant run modifications are always good to have as well.
The only issue I have with this, is if you're running water too fast then it doesn't pick up heat as effectively because it's not spending enough time in the cooler.
1987 GT-S -> rust in piece
1991 RC -> project http://www.alltrac.net/phpBB2/viewtopic.php?f=44&t=44216 "Darlinda the Tie Fighter"
1992 GT-S -> daily
2000 Cherokee -> ski hauler
1997 Prelude -> girlfriends daily/project "Charmeleon"
Postby zero06 » Wed May 16, 2012 2:48 am
High volume fixes all problems, I'm going BIG for my heat exchanger and adding a reservoir, Audi had run an evaporator in their water reservoir off of their ac compressor in rally. I've been toying with the idea, being an HVAC/refrigeration mechanic.
zero06
Postby Mafix » Fri May 25, 2012 1:52 am
underscore wrote:I'm guessing that a good way to tell when your intercooler is reaching it's limits would be an IAT sensor, because typically the stock setup is still good for near-stock applications. Because you basically want the smallest cooler for your power levels to reduce lag.
that is a problem of the fluid being used. not the speed of it moving. we are not talking any kind of serious flow here. just constant and consistant. you think the 25 year old toyota pump is up to that?
Built Gen 1 3SGTE,Megan,Autopower,Forza,Precision,Haltech,COP,Racepak,FMIC,Nitto,CRW axles,Quaife,V6 trans,Competition Clutch,Fidanza,Moroso,ST,370whp,340tq
Sponsors: Midas, SRT, Paradise Racing, CRW, ST162.net
Postby 88gt4DE » Fri May 25, 2012 10:35 am
I just did gauges on mine and I added a temp gauge to the output side of the intercooler to be able to monitor the temp of the coolant. Never liked not be able to tell how hot that really was or able to see if upgrades , constant run , fan , etc made a difference at all ....
1988 ST165 - 72K - Project ---> http://www.alltrac.net/phpBB2/viewtopic.php?f=44&t=31483&start=240
2000 Toyota Tundra SR5 - 150K - DD - Thanks 97JZA80
2007 Toyota Rav4 - 70k - My girls DD - Paid off !
Postby zero06 » Fri Jun 08, 2012 5:37 pm
zero06
Postby darthripley » Sat Aug 25, 2012 1:48 am
I've had the ARC & now have the ST205 WTA ... honestly there is no comparison between the 2 units.
The ARC is an improvement over the stock A2A TMIC, but if you live in a climate where ambient temps get above 90F then it's just as useless as the stock interheater.
I put in some Water Wetter into the ST205 core & it works like a champ. Of course it gets hot too as it sits right over the motor, but I don't notice the heatsoak as badly as the ARC.
So from my experience, I'd put the ARC/Bay Area under the stock 185 A2A, then the ST185 CS WTA.
This is a good reference thread though for those new to the car & looking for OEM I/C mods.
87 AW11 MR2 "Super 2" 4AGZE
99 SXV20 Camry "Maul" 5SFE
Female Moderator
darthripley
All Trac Goddess
