Any lightweight pulleys out there?
Postby celigts » Wed May 09, 2012 5:01 pm
Mafix wrote:unless you are moving to the ATI fluid dampener which is about 2 lbs lighter than stock for 3 times the cost, then leave your pulleys alone.
won't be doing that as I don't even know what that is
3SGTE project motor very slow
celigts
Re: Any lightweight pulleys out there?
Postby Hotrodhendrix » Wed May 09, 2012 5:40 pm
You can always media blast your stockers and powdercoat them if they are ugly... Other than that its accessory pulleys.
Postby Mafix » Wed May 09, 2012 6:54 pm
removing accesories that aren't needed seems to be the BEST answer.
Postby Hotrodhendrix » Wed May 09, 2012 6:56 pm
Mafix wrote:removing accesories that aren't needed seems to be the BEST answer.
Pssshhh A/C in Texas is not an accessory :lol:
Postby 94 MR2 Turbo » Wed Jul 04, 2012 1:50 pm
Ati crank pully?? For 3sgte? I never knew one was offered.
94 MR2 Turbo
Postby masco » Fri Jul 27, 2012 11:52 pm
Yeah, I can't find one on their website. I really need a crank pulley right now. Neither ATI or Fluidampr list them on their site.
1990 Turbo4wd - 1990 Corolla GT-S - 2002 RX300
masco
Postby 94 MR2 Turbo » Thu Aug 16, 2012 8:39 am
does ati make one for the 3s?
94 MR2 Turbo
Postby darthripley » Sat Aug 25, 2012 2:02 am
It's a rubber dampner on the crank pulley intended to help make engine internals last longer due to vibrations caused by the motor.
You can run a solid aluminum pulley but you will likely find more metal shavings in your oil pan in the future & loads of premature wear on engine internals like valves, pistons etc.
I read a great article about the wear years ago when someone installed an aluminum crank pulley on their Sentra R - the pics of the engine ripped apart after several thousand miles was pretty amazing.
I'm not sure if the page still exists, I'm too lazy & too old to try to search right now.
There's really no real need to run a lightened underdrive pulley on a street car.
As was mentioned above, do things to remove weight from the drivetrain itself + run lighter weight rims.
You've heard of unsprung weight right?
Install a C/F driveshaft which is a ~30lb weight savings over stock, lightened f/w, shimless (shim under buckets)
Make what you have more effecient, then do things like strip the interior if you want to go deaf, tear out the A/C so you can burn up & tear out the power steering so it will be as uncomfortable as possible to drive.
Speaking of Sentras makes me think of the magazine that "made" a kid's Sentra a 10 second car. Good stuff. :twisted:
87 AW11 MR2 "Super 2" 4AGZE
99 SXV20 Camry "Maul" 5SFE
Female Moderator
darthripley
All Trac Goddess
Users browsing this forum: Google Adsense [Bot] and 6 guests
