St165 power loss?
St165 power loss?
Postby jaydog82 » Sat Jun 09, 2012 12:37 am
I think I am having a power/ alt problem or a grounding problem. When I drive my alltrac hard it feels like there is something holding me back, and sometimes my battery and brakelight come on and Sheri so often I get a cel for no power to the edu. Anyone had a problem like this?
jaydog82
Re: St165 power loss?
Postby 88gt4DE » Sat Jun 09, 2012 12:43 am
Yes, check the wiring over the alternator. It gets cooked from the heat and then makes it not charge. Not staying thats yer problem for sure but it a common thing to check first ...
Postby jaydog82 » Sat Jun 09, 2012 12:49 am
Ya I'm Gona check that and add some grounds and see if that helps
jaydog82
Postby jaydog82 » Sat Jun 09, 2012 1:13 am
This is starting to make more sence to me, this would explain why my car feels more powerfully when it is cold. I have never had this problem, is it pretty comen on the 3sgte? Any good fixes other than heat wraping the alt wires?
jaydog82
Postby 88gt4DE » Sat Jun 09, 2012 10:40 am
Gonna have to repair it somehow , wire and shrink wrap. Sometimes the copper inside the wire will break and outside rubber will still be attached ( you prol know that already , just a note 8) ) I have a similar issue with my cooling fans where they will kick on and off erratically when engine compartment is hot , just havent been able to locate the break ...
Postby jaydog82 » Mon Jun 11, 2012 2:52 am
so it turns out that my alternator was bad, i still think that my car should have more power. maybe im just to use to it and feel the need for more :)
jaydog82
Postby 88gt4DE » Mon Jun 11, 2012 11:00 pm
well good to hear you got it fixed. Yes you get use to the power and then want more :) do you have a downpipe in place of the cat yet ?
Postby jaydog82 » Mon Jun 11, 2012 11:55 pm
I have a 3" aussie dp installed, but i still have the lower cat that i need to remove.
jaydog82
Postby 88gt4DE » Tue Jun 12, 2012 12:02 am
well , better than with the big cat in for sure with the downpipe in it ... List is endless for upgrades , just gotta make sure motor can handle it and start throwing parts at it :wink:
Postby jaydog82 » Mon Jun 18, 2012 5:03 am
Ya it had way more power with the dp.
jaydog82
