ATS Throttle Body Inlet Question
Postby ALLensTRAC » Mon Jun 18, 2012 7:25 pm
Hey guys just wondering what you guys used as a gasket between the Inlet and the TB? Is there a gasket for the MR2 that I can order or should I just make one? If there is a factory one available do you have the part number as our local dealer won't look anything up without a vin.
Thanks in advance,
Allen
Allen
ALLensTRAC
Re: ATS Throttle Body Inlet Question
Postby ALLensTRAC » Tue Jun 19, 2012 2:03 pm
Bump! Anyone have an answer? Pretty Please :)
Allen
ALLensTRAC
Postby l00k0v3rth3r3 » Tue Jun 19, 2012 5:54 pm
i do believe this is what you are looking for 22271‑88381 ... as a side note toyodiy.com will help you immensely when looking for part #'s
Gabe
1990 Maroon Audi 90 Quattro
1998 Toyota 4runner Limited
1991 Mazda Miata 1.8l
l00k0v3rth3r3
Postby ALLensTRAC » Tue Jun 19, 2012 6:06 pm
Thank you for the number. The last time I used toyodiy it sent me in the wrong direction lol. I will try it again with this and see what it gives me. Thanks again for the help, Allen
Allen
ALLensTRAC
Postby cmonteiro1 » Tue Jun 26, 2012 8:49 pm
I have done this two ways. 1st time I used silicone to seal the inlet to the throttle body. 2nd time, I made a gasket with gasket paper I had lying around.
1991 ST185
Mods:
Aussie DP, 3in Exhaust, Wideband A/F, BayArea FMIC, HKS SSQ Blow Off Valve, Forge Waste Gate Actuator, AEM ECU, SARD 800 , Walbro Pump, ATS Fuel Rail Mod, ATS Fuel Pres. Reg. Mod., 60 trim upgraded ct26.
cmonteiro1
