What numbers do I look for on the uego
Postby celigts » Tue Jun 26, 2012 7:02 pm
So when I get my uego wired up I'm wondering what are some numbers for the mixture I should be seeing as "normal".
I currently have an aem dryflo intake filter after the afm. 2.5" mandrel bent exhaust from front support brace back. To install the wideband we know we need a dp to install it so I'll have a 3" berk dp with flex pipe.
So with this info I wanna see how different numbers will be from stock.
What do you guys get?
3SGTE project motor very slow
celigts
Postby celigts » Thu Jun 28, 2012 11:03 pm
Anyone give me some input
celigts
Re: What numbers do I look for on the uego
Postby klue » Fri Jun 29, 2012 3:05 am
in boost generally 11.0 or less usually on an AEM you will get 10.5 or less
Postby jaydog82 » Fri Jun 29, 2012 3:31 am
Im reading around 10.0 in max boost and around 12.0 to 12.5 crusing
jaydog82
Postby celigts » Fri Jun 29, 2012 10:33 am
Thanks guys! This is what I was looking for.
celigts
Postby celigts » Fri Jul 06, 2012 3:00 am
K so got the uego all wired and working and at about 100km I'm getting between 14.3-15.1 under boost it says 10 but pretty sure it's alot less and idle is about 15-15.4 or so
celigts
Postby l00k0v3rth3r3 » Fri Jul 06, 2012 3:45 am
mine has a much wider swing, under boost i get anywhere from 10-12...cruising I'm generally at 14-14.5 and idle I'm sitting at 17-18....and downshifting I'm showing upwards of 20
Gabe
1990 Maroon Audi 90 Quattro
1998 Toyota 4runner Limited
1991 Mazda Miata 1.8l
l00k0v3rth3r3
Postby celigts » Sun Jul 08, 2012 10:43 am
I can't see numbers past 18 and even that's at the top. When I'm in full boost at .7 bar it's at a solid 10 and I do think it's more like 8-9.
celigts
Postby toayoztan » Sun Jul 08, 2012 5:22 pm
On a stock set up (stock boost), I was seeing 10-10.2 on full boost with my PLX.
Turned the boost up to about 14 pounds, I was seeing 10.5-11.
On idle, you should see anywhere from 14.5-15.5 (around stoich).
When you cruise, it just depends on cruising speed, load, how much throttle you give, etc.
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
1977 Celica GT Liftback
2015 Grom
1977 GL1000
toayoztan
