Down Pipe Install - Please Help - Video
Postby awolo » Fri Jul 13, 2012 10:48 pm
Hey guys. I know your probably thinking, "oh great, another down pipe install thread"....well, yeah.
I need some advice on what to do next. Please disregard my dirty a hell engine bay. She is getting a complete overhaul soon!
I cant keep breaking bolts and parts, its getting redic. :bangshead:
Click my vid:
Link:
http://s285.photobucket.com/albums/ll56 ... 53_772.mp4
Any advice/guidence is much appreciated. :notworthy:
awolo
Re: Down Pipe Install - Please Help - Video
Postby jaydog82 » Fri Jul 13, 2012 11:08 pm
The vid did not work, post a link. Once u remove all the bolts for the do then remove the oil filter and work on dropping the do down by twisting and giggling it should go down and towards the driver side.
jaydog82
Postby celigts » Fri Jul 13, 2012 11:08 pm
K so from my phone all I get is a pic and as far as the pic goes looks like you still need to remove the oil filter, loosen the manifold bolts and you should win.
3SGTE project motor very slow
celigts
Postby awolo » Fri Jul 13, 2012 11:13 pm
I posted a link.
You have to click on the pic.
Anyway, I have the manifold bolts all the way loose and I still cannot get the down pipe out. Its not hitting on the oil filter. Its hitting on the filter housing where it screws in.
Ive tried EVERYTHING to wiggle it out. I just cant get it over the bottom two studs that hold it to the turbo.
awolo
Postby Corey » Fri Jul 13, 2012 11:42 pm
When I removed mine I had my motor out, but I recall removing the Cat from the upper portion of the downpipe first. If you can remove that bottom section first, it might help.
Edit: NM just watched the video lol I see you already have it off....
I'd also suggest removing that filter - it can't hurt. If you're really desperate maybe you can use a hacksaw to shorten some of those studs a bit. Then to replace them you can thread a couple nuts onto the shortened studs and use the inside nut to back the stud out. Might as well replace the studs while you are there, they are cheap from toyota.
Orr since you already have the exhaust manifold loosened up, you may want to replace those gaskets. So might as well just remove the entire turbo/manifold/downpipe in one piece. That's how I reinstalled my setup while the motor was out. I installed the KOracing downpipe to the turbo first, then installed the whole setup to the engine with new gaskets.
Corey
Images: 50
Postby loudstealthGT-Four » Fri Jul 13, 2012 11:46 pm
you could try,
cutting the ends of the two studs that are causing you greif?
removing the two studs (if that would be easier than cutting/ would recommend giving the studs a good spray with a anti-seize/penetration lubricant)
or if everything else fails, bash it with a hammer (usually sorts things out :evil: :D )
loudstealthGT-Four
Postby BoostedBlueToyotas » Fri Jul 13, 2012 11:58 pm
Its been awhile but I am pretty sure you have to move the oil cooler (the base under the oil filter). You have
to remove the 30mm bolt holding the oil cooler to the base. Since putting this back together is a pain (Its almost
impossible to rethread that big bolt back in without crossthreading it into the pewter base which then cracks and
then you have to replace it). Note that is with the stock DP only, aftermarket ones dont have the clearance issues that the cast iron stocker does
Maybe you can loosen the exhaust manifold and slide the manifold/turbo/downpipe forward enough to give you
enough clearance to slide the downpipe off. Just watch so you dont kink the water and oil feed lines to the turbo
if you try this.
Tim Plessing
Columbia, MD
BoostedBlueToyotas
Postby 4rsnduction » Sat Jul 14, 2012 1:12 am
Since you have loosened the bolts that hold the exhaust manifold onto the head you might want to use a fresh gasket
Your going to need to remove the turbo and its water/oil lines and exhaust manifold anyways, doing all that should get your dump pipe out by default, also gives u good chance to inspect everything.
4rsnduction
Postby awolo » Sat Jul 14, 2012 1:23 am
This is all GREAT information.
I don't have the parts to replace the exhaust manifold gasket of that damn stud I broke.
I have loosened up the Exhaust Mani bolts, but the manifold only comes out to a certain point. If I had another 3mm I could get it off. But im not sure whats stopping the manifold from moving. Maybe the turbo and what not.
I need to be able to drive the car by Monday for work.
Looks like i'm going to spend my Saturday under the hood.
And I havenet even gotten far enough to figure out getting the mid-pipe over the sub-frame.... :|
awolo
Postby celigts » Sat Jul 14, 2012 2:32 am
Could be the turbo oil lines not letting you move far enough out. I also took the dp out of the mid pipe for more movement. If you haven't done that either.
Kind of off topi but can the exhaust manifold be moved out enough to replace the gasket without removing the turbo? Don't think so eh?
celigts
Postby Corey » Sat Jul 14, 2012 2:53 am
You'll need to unbolt the oil line from the block (will need to replace both gaskets for the banjo bolt) and there is a turbo support bracket holding the turbo to the block which will need to be undone. You may need to disconnect the upper rad hoses but they might be flexible enough.
Corey
Images: 50
Postby awolo » Sat Jul 14, 2012 10:40 am
It seriously cannot be that intricate to get the down pipe off. All the searching I did, didnt even mention removing the turbo and all this.
If I new I was going to have to replace all these bolts, gaskets and remove the turbo, I would have waited till I had all the parts and done this right.
Sh*t.
Well, its 7:41am....time to start.
awolo
Postby loudstealthGT-Four » Sat Jul 14, 2012 11:03 am
It can be done without removing the turbo.
When I swapped mine to an aftermarket one I didn't have to,
remove turbo
loosen off the manifold bolts.
Only problem is, I can't remember what I did to get it off, I think i may have just cut a couple (mm) off the end of the stud that it was catching on?
loudstealthGT-Four
Postby BoostedBlueToyotas » Sat Jul 14, 2012 1:49 pm
The stock DP hangs up on the oil cooler, not by much but enough that you have to move it :(
Tim Plessing
Columbia, MD
BoostedBlueToyotas
Postby Corey » Sat Jul 14, 2012 2:07 pm
It might be the case that when those old crusty nuts are removed from the studs, a few studs get pulled out along with them. This would really help with removing the pipe
I think the easiest way would be for you to start cutting up studs (make sure to leave enough thread on them to remove with 2 nut method)
Corey
Images: 50
