Water/ alcohol injection 3s
Postby jaydog82 » Mon Jul 23, 2012 12:53 am
I have been looking into water/ alcohol injection for my st165 and I have decided to build my own. Does anyone have any experience with this?
jaydog82
Re: Water/ alcohol injection 3s
Postby 94 MR2 Turbo » Mon Jul 23, 2012 3:48 am
I have installed a few kits and all are lengthly processes. The best kits are Aquamist kits but there is alot to them. Are you parting one together? are you using a boost activated switch? Are you looking to use Meth or water? what is your goal? Do you have a way to utilize the added drop in intake temps? Planning on adding timing? or just raising boost?
94 MR2 Turbo
Postby Mafix » Mon Jul 23, 2012 1:49 pm
you need to read corky bells book.
Postby jaydog82 » Mon Jul 23, 2012 3:07 pm
I am going to put one together, going to use a pressure switch to activate. Im not going to use meta right now, just 50% water and 50% alcohol. Im not planning on running more bust just yet, but I have been looking into ways to up the timing. Im really just looking to increase the effectiveness of my wta ic and keeping the pistons nice and clean.
jaydog82
Postby underscore » Mon Jul 23, 2012 4:40 pm
I've got an AEM kit, I need to decide how to run the line to the front of the car & then make/buy a tap for the TB coupler.
Postby jaydog82 » Mon Jul 23, 2012 6:23 pm
Well I already have a free pump so making my own sounds more practical. Are you using a check valve or a solinoide?
jaydog82
Postby underscore » Tue Jul 24, 2012 4:20 pm
Whatevers in this setup http://www.aemelectronics.com/water-met ... ngines-51/
I picked it up on the cheap but I'm still sorting out how I want to use it
