Need Advice - No Power & BAD MPG
Postby awolo » Mon Aug 06, 2012 12:29 pm
Whats up guys.
Im having some issues with my AllTrac and I need your help. I'm getting much more familiar with these amazing cars but, I need you veterans to lend some knowledge or maybe point something out that im not thinking of.
My car is my DD and I have not been driving it at all these past 3 weeks. Thank god for motorcycle's and good weather.
PROBLEM:
The car makes boost to 15psi - But she has NO pull/kick.
My mileage has been between 9-11 MPG!!!
As of late, she has been pushing coolant into the overflow bottle, enough to fill it up and have it drain out.
Here's the last months history. I'm going to be as accurate as possible so you guys have all the facts.
My stock exhaust was rusted out horribly, loud, and rattled. So it needed changed.
I replaced it with a full 3" cat-back. I also removed the stock cat and went with a 3" down pipe. Install was a PITA but she sounds great!
At this same time I installed, new NGK 6RE's and plug wires.
Upon my ehxaust install, I broke a exhaust manifold stud. So I had a leak which leaked all my boost, thus leaving me with no power and horrid mileage. I replaced the stud, she is nice and tight. Also made sure all of my down pipe bolts are staying tight, as they have been loosening themselves. :bangshead: See thread: viewtopic.php?f=50&t=44924
For maybe a drive or two, she was running GREAT. Pulled hard but still had bad MPG. But then went back to no power. I checked and re tightened loosened bolts.
I pulled the ECU fuse to let the car reset itself. Didn't help.
I do not have a constant CEL.
The car does not smoke, stutter, sputter, hiccup, anything. Turbo spools up fine as well. Small oil drip, but has been that way since purchase.
It is obvious that there is something wrong with the vehicle. No power + bad mileage would point to a exhaust leak or a boost leak. To the best of my knowledge, I no longer have any leaks.
Before I start throwing parts at her, which is never a good thing with problems. I have some questions for thought.
[b]QUESTIONS:
1. Do you guys think that my O2 is bad? Possibly killed it when the stud bolt was broke and she ran super rich? Thus causing my bad MPG and no power?
2. Should I look into maybe using different plugs/wires?
3. It is possible that even though all the down pipe and exhaust manifold bolts are tight, I still have a big leak somewhere? (kinda leaning this way)[/b]
I know that throwing on some wider would hurt my MPGs and pull, but from 20-22 down to 9-11??
Any advice is GREATLY appreciated. I don't want to let this car go.
awolo
Re: Need Advice - No Power & BAD MPG
Postby 4rsnduction » Mon Aug 06, 2012 12:48 pm
A good way to get solid answers is to have a smoke test performed on the engine.
Remove the brake booster vacuum line and introduce smoke to the engine and intake system via this port.
Use WOT so smoke can reach the air filter, but u dont want smoke and pressure to escape so plug the filter box hole with a rag.
If no smoke is detected this way then open the oil filler cap, drain all the coolant and introduce smoke via the radiator fill cap.
Smoke will fill your radiator and engine, if the head gasket is on its way out then smoke will invade the cylinders and escape out the exhaust/intake or smoke will escape via the oil filler hole.
This test will also find any exhaust leaks.
Any decent shop should have a smoke tester and if u tell them exactly how u want it tested there is less room for error.
85% of the time smoke tester will find your problem, at the very least if it finds nothing u now know its an electrical gremlin.
4rsnduction
Postby awolo » Mon Aug 06, 2012 2:20 pm
That....is an unbelievably good idea.
awolo
Postby jaydog82 » Mon Aug 06, 2012 2:36 pm
Do u have a wide band on it?
jaydog82
Postby awolo » Mon Aug 06, 2012 4:11 pm
jaydog82 wrote:Do u have a wide band on it?
No wide band. Car was completely stock + MBC before exhaust install.
awolo
Postby jaydog82 » Tue Aug 07, 2012 6:01 am
Id be careful running that much boost without a sideband.
jaydog82
Postby Kil'Jaden » Tue Aug 07, 2012 6:19 am
I'll start off with "I don't know", but I do know anytime I end up breaking a seal on my old mustang, its a good idea to replace it. My best guess is the problem is still around that previous leak, just maybe more subtle.
Kil'Jaden
Postby Mafix » Tue Aug 07, 2012 11:08 am
your knock sensor is pulling timing because you have a blown headgasket. you are getting water in the cylinder and causing detonation. so long story short....new hg time.
Postby 4rsnduction » Tue Aug 07, 2012 11:26 am
Mafix wrote:so long story short....new hg time.
Smoke test to confirm that would be a good place to start if your serious
4rsnduction
Postby awolo » Tue Aug 07, 2012 11:37 am
Mafix wrote:your knock sensor is pulling timing because you have a blown headgasket. you are getting water in the cylinder and causing detonation. so long story short....new hg time.
I understand what your saying. But if it where the HG, wouldn't I have smoke out the exhaust?
I have never noticed/seen/had anyone tell me about smoke coming out of my exhaust.
I'm going to be looking into a smoke test ASAP.
awolo
Postby Mafix » Tue Aug 07, 2012 11:48 am
not necessarily. head gaskets blow in many ways. the most common on these cars is a coolant passage to the combustion chamber. because these are forced induction they tend to blow more air into the coolant system then they get coolant in the combustion chamber.
Postby awolo » Tue Aug 07, 2012 12:10 pm
Mafix wrote:not necessarily. head gaskets blow in many ways. the most common on these cars is a coolant passage to the combustion chamber. because these are forced induction they tend to blow more air into the coolant system then they get coolant in the combustion chamber.
This is not what I wanted to hear. But thank you for your input. It is greatly appreciated.
I'm going to look into a smoke test. That will tell me which way to go.
awolo
Postby awolo » Tue Aug 07, 2012 12:20 pm
4rsnduction wrote:A good way to get solid answers is to have a smoke test performed on the engine.
I KNOW this is a stupid question, but this all gets done with the car not running correct?
awolo
Postby 88gt4DE » Tue Aug 07, 2012 12:31 pm
Correct :wink:
Postby awolo » Tue Aug 07, 2012 3:17 pm
Thought so. :oops:
Anyway, im borrowing a smoker today/tomorrow and im going to give this a shot. Ill be sure to report back ASAP.
Im curious though. The car ran top notch before the exhaust install / broken manifold stud / etc. Does anyone have an idea as to what "may have" caused the motor to blow the HG?
awolo
Users browsing this forum: Bing [Bot] and 3 guests
