ST185 conversion to ST205
Re: ST185 conversion to ST205 POST Suggestions!!!
Postby OutToWinPAHC » Mon Sep 10, 2012 2:40 am
Wait are you thinking about ditching the ATW for the front mount? or using them at the same time. The top mount ATW with a properly sized turbo will be more effective and have less boost pressure drop which will allow for more power, and faster response. The front mount looks big, do you know the core thickness and inlet outlet sizes?
I am on the tail end of saving my ST185 and I have been tossing the idea of front mount VS TOP. For now I am using a CT26 with a billet Garrett GTX compressor wheel and will use the top mount with a fan. If it does not cool effectivly I will be considering ATW but it will be a custom unit built from scratch.
As for motors you say rebuilt VS a used. I been doing high performance cars for a long time and the term rebuilt is loosely used and often farse. Unless you have the paperwork, blue printing or receipts it's hard to say what you have. If you have those I would use that motor and sort the issues you have. I picked up a R33 with a fully built and blue printed motor last year and it was a wiring mess and didn't run. A new harness, time, and schematics I turned a 20K trade into a 40K car. Just keep that in mind.
1990 ST185 All-Trac 54trim
1993 Nissan Skyline R33 GTS25T-M widebody built 60trim R34 NEO AEM-Series 2
OutToWinPAHC
Postby tw2 » Mon Sep 10, 2012 5:50 am
+1 for the engine out the bottom. I also just used my engine hoist around the bumper support. I didn't have a dolly though. I used the engine hoist to roll the car out from on top of the engine.... very risky procedure.
Thomas, JDM 90 185, 06 350z
tw2
Postby Overtriped » Wed Sep 12, 2012 11:10 pm
Was trying to find the best solution for brakes. Thought about Toyota pickup 4pots, 205, Brembos
From a porsche, supra brakes, highlander brakes. A lot of options.
I think I've decided to go with these though , ( after my car runs
And looks clean) Image
What do you guys got?
90 ST185~205
04 Tundra V6 5spd 2wd
TOYOTA JUNKIE
Overtriped
Postby Overtriped » Sat Sep 15, 2012 11:43 pm
Got my tools moved in and cleaned the garage im Renting. Took her out for the last drive before surgery, jogging lady screaming at me "SLOW DOWN" *shakes fist* I only acellerated as fast as it could In 1st and 2nd- was going the speed limit, it's just REALLY loud! Haha!!
90 ST185~205
TOYOTA JUNKIE
Overtriped
Postby Overtriped » Fri Sep 28, 2012 12:05 am
After many hours hard at work in the garage we now have the motor/tranny/wiring harness out of the car. Thanks to this forum I was able to do this rather smoothly! I bought that massive lift, it worked really well with a couple chains and shackles. Also got some 17x7 scion TC wheels. Stripped out my rear interior. Now I'm cleaning the engine bay and waiting for my used 205 setup to arrive. Need a New PS system.
90 ST185~205
TOYOTA JUNKIE
Overtriped
Postby underscore » Fri Sep 28, 2012 5:13 pm
Holy crap now THAT is an engine lift!
Postby Overtriped » Fri Sep 28, 2012 9:01 pm
Haha, bought that on Craigslist and had it delivered. I had no clue that it was going to be that large until the guy showed up with it. It had about a half inch of clearance to get in to the garage lol. Worked great though!!
I measured my IC core and its 3x12x24 (this is just the coil size not including both headers) the inlet/outlet size is 2 inch. Any ideas what this beast will handle?
90 ST185~205
TOYOTA JUNKIE
Overtriped
Postby tw2 » Fri Sep 28, 2012 9:06 pm
That intercooler will be fine, that should cool whatever you throw at it.
Yeah that hoist is huge. Tucking it neatly away when your finished with it might be an issue :lol:
tw2
Postby Overtriped » Thu Nov 08, 2012 9:05 pm
After this discovery the entire rear end is comming apart.
Anyone run across this? :doh:
90 ST185~205
TOYOTA JUNKIE
Overtriped
Postby tw2 » Fri Nov 09, 2012 4:42 am
Shit'll buff out.
Sorry to see that, I have seen this happen before espcecially you guys who live in areas they salt the roads.
tw2
Postby sMARTINside » Fri Nov 09, 2012 9:14 am
My car had the same problem, starting, not like yours. I cut all that metal and welded new sheet metal around to solidify it.
sMARTINside
Postby 4rsnduction » Fri Nov 09, 2012 11:20 am
Thats one rusty rear end....
4rsnduction
Postby Overtriped » Sat Nov 10, 2012 10:20 pm
I'm thinking if grinding it back to the square tubing that its attached to and fabricating a new bracket that is about the same size as the other one. I'll post up my rear end teardown pics - lets see what treasures lie Beneath. Nice tercel btw, thoes cars are fun to drive!
90 ST185~205
TOYOTA JUNKIE
Overtriped
Re: ST185 Project wants input.
Postby Overtriped » Mon Mar 25, 2013 3:03 am
Haven't posted in a bit.. Ive decided to rebuild my JDM st185 motor for now, got stiffed for the 205 setup. Gonna work with what i have. Sold my stock AT hood and bumper today, and also picked up a good 3sgte shortblock from a wrecked 93. Has some miles on it but everything seems to be in good condition.The shortblock has never been apart, or rebuilt. Cylinder walls look nice and smooth, could use a honing. Ill prob. take the whole thing apart, check clearances, clean it up and repaint it. I might get another longblock setup for a decent price, but that one has been rebuilt and has a scored cylinder wall. ( I dont like the idea of boring it twice, or at all really...) Other than the bored,scored block that might be a good thing to have on top of this 93 usdm shortblock and my ?year JDMst185... Could prob make one good motor with 3 right? haha... other than buying rings, gaskets and all the non reusable stuff.
I'm going to talk to my freind who has a valve grinder and try and do the shimless bucket conversion with a nice valve job. Trying to get a 3sge Side feed intake plenum... working on that... prob. run the stock cams and gears right now... also will be using my good ct26 on this engine. Eventually id like to build a 5sgte and get a nice Garret with a standalone. Untill ive got 6k to spend on that ill try and use what i got in front of me. After all its not a bad pile of parts.:) ill post pics in a sec...ImageImageImage
I just hope the corrosion in the water jacket isn't going to be an issue with this block...
90 ST185~205
TOYOTA JUNKIE
Overtriped
Postby mixer72 » Mon Mar 25, 2013 12:32 pm
id get the block chemically cleaned and see how it looks after that
mixer72
