Exhaust ?
Exhaust ?
Postby Hotrodhendrix » Tue Sep 18, 2012 2:57 pm
The plan was for a semi quiet free flowing 3' exhaust. Basically high flow cat, 12' glass pack style muffler and large straight through muffler. I come to find my current downpipe is 2.5' and at the connection point it expands to a 3' pipe back.
would this be considered a bottleneck as its only a few inches further down the exhaust path before it expands to a full 3' diameter?
~James
Re: Exhaust ?
Postby underscore » Tue Sep 18, 2012 3:18 pm
Technically yes, also any changes in diameter can cause turbulence if not done right.
Exhaust ?
Postby celigts » Tue Sep 18, 2012 7:42 pm
Your way would be better then mine I think tho cuz I have a 3"dp and 2.5" exhaust. :/
3SGTE project motor very slow
celigts
Re: Exhaust ?
Postby tw2 » Wed Sep 19, 2012 7:26 am
If you are after every single individual hp then yes, otherwise don't worry about it. I got a 3" downpipe made ages ago. When I came to make the exhaust I could not make the 3" quiet enough so went with a 2.5" setup, very quiet.
Thomas, JDM 90 185, 06 350z
tw2
Re: Exhaust ?
Postby Hotrodhendrix » Wed Sep 19, 2012 11:47 am
Thanks for the responses. I think for now I will just do 2.5-3 reduction piece after the connection point so that it expands evenly. If I ever do go for big numbers I can alter that fairly easily.
~James
