HKS Specs?
HKS Specs?
Postby FWD-3SGTE » Sat Sep 22, 2012 11:17 pm
I'm looking for a few specs on some of my head pieces, HKS is terribly hard to contact apparently and I can't seem to find any online but I may not be looking in the correct places. If any of you can help me out, that would be awesome! I need the following specs for my machine shop so we can make sure the springs are strong enough for the cams and maybe figure out why my valves have been floating, one bad enough to kick out a shim. Here are the figures I need...
Valve lift for each cam (264 deg intake and exhaust)
Spring assembled height and pressure followed by open pressure.
Cams and springs are both HKS, just noting this so no one asks to make sure ;)
FWD-3SGTE
Re: HKS Specs?
Postby fussellbug » Sun Sep 23, 2012 12:00 pm
Camshaft valve lift specs can be found here:
http://www.hkseurope.com/engine/apps/camshaft.htm
fussellbug
Images: 36
Re: HKS Specs?
Postby FWD-3SGTE » Tue Sep 25, 2012 11:24 am
Yeah, I found that soon after I wrote the original post :P
Now I'm searching for the spring specs which are impossible to find!
FWD-3SGTE
Users browsing this forum: No registered users and 7 guests
