ground on intake manifold!!
Postby xaftermath801x » Wed Oct 10, 2012 1:30 am
so its been a minute since i studied the schematics of the st165 harness but i need to know what is grounded to the center bolt of the intake manifold to diagnose some issues im having. I couldnt find anything to define what is grounded on any of the celica techs bgb references. so if anyone from memory can tell me youd save me alot of headache. thanks!
88 st 165/w 185 swap sold :(
88 st165 revival in progress sold :(
93 mkiv supra NA-T (601whp at 19psi on e85) 1000hp goal build in progress
97 dodge 1/2 ton lifted and beaten to death daily.
13 dodge dart (not as fruity as a prius)
xaftermath801x
Re: ground on intake manifold!!
Postby Dracov » Thu Oct 11, 2012 12:35 am
If I remember right there is a ground strap coming out from the wire harness in between the #2 and #3 fuel injectors that gets bolted to the back of the intake manifold.
1988 Toyota Celica Alltrac
Dracov
Postby xaftermath801x » Thu Oct 11, 2012 2:44 am
i know this. im asking what is grounded thanks.
xaftermath801x
Postby phattyduck » Thu Oct 11, 2012 5:05 pm
Injectors (through ECU), engine sensors, ECU...
'99 4Runner SR5 4WD 5VZ-FE
phattyduck
Postby esracing » Thu Oct 11, 2012 5:20 pm
its for the efi system.all of it sensors ecu all
2008 tundra blue
1988 st165 white imsa gto
1969 camaro 502 bb 630 hp black
esracing
Postby klue » Thu Oct 11, 2012 9:52 pm
its kinda important LOL
Postby xaftermath801x » Fri Oct 12, 2012 3:27 pm
thats what i figured to be the case i just am diagnosing no spark issues. and i have narrowed it to wiring. so i wanted to trace some connections that way. i know its important lol :P
xaftermath801x
