CT20B
CT20B
Postby MARLON1211 » Fri Aug 20, 2004 2:25 pm
this year am lookng to buy a CT20b, and I know this is a direct bolt on. I've heard fom the MR2 guys that this is one of the most reliable and most powerfull than a CT26. And lots of low end torque, and low end power.
Anyone has this convertion and pls give me your opinion on the comparisson on the old 26s to the 20s. For a (ST85). Thanks.
Marlon1211
SO BE IT
MARLON1211
Postby Gary » Fri Aug 20, 2004 2:27 pm
93 ST185
Gary
Postby ChrisD » Fri Aug 20, 2004 2:39 pm
edit
1988 ST165
1994 ST205 WRC
ChrisD
Postby gt4tuner » Fri Aug 20, 2004 2:39 pm
I don't have a CT20B, but I have driven my friends MR2 with the CT20B and a guitted cat and damn that thing spools up quick. It also keeps steady power all the way up the RPM range. Like Zeus says it would be a great turbo for auto-x.
gt4tuner
RE
Postby MARLON1211 » Fri Aug 20, 2004 2:56 pm
Yes you're right, and it cost way less than T3/T4. I know T's are good and is more high performance but if you're like me with limited resorces like (money). I would like no complication like tuning, manifold, Dp etc to make it work, and assembled right. Besides my goals is not too radical just around 13s, with stock engine, and little fuel mods. Thanks.
By the way never really seen one upclose, just how big is this compared to a ct26.
Marlon1211
SO BE IT
MARLON1211
Postby busdriver » Fri Aug 20, 2004 8:44 pm
How much does a good CT20B generally cost?
Jake
90 st185
needs tlc
busdriver
Postby Gary » Sat Aug 21, 2004 4:03 am
busdriver wrote:How much does a good CT20B generally cost?
$700 more or less.
93 ST185
Gary
Postby zblu81 » Sat Aug 21, 2004 5:38 am
they're are physically really close to the same size.
[b][/b]Greg
Lansing, MI
'92 turbo All-Trac
3" Exhaust, RC intercooler, ATS TD06-20g, stage2 clutch
zblu81
Postby ChrisD » Sat Aug 21, 2004 3:37 pm
edit
1988 ST165
1994 ST205 WRC
ChrisD
Postby toayoztan » Sat Aug 21, 2004 6:00 pm
I do hear one drawback is that no one in the states rebuilds these turbos. So aren't we taking a chance on the how long they last when we get them? i think someone did mention back on the old board that Majestic Turbo can rebuild these. Anyone want to give some info or clarrification on the ct20b being able to be rebuilt and also, info on Majestic Turbo? (might as well, since we have a fresh board heh)
Thanks!
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
1977 Celica GT Liftback
2015 Grom
1977 GL1000
toayoztan
Postby MARLON1211 » Mon Aug 23, 2004 12:48 pm
Does the 20b fits in a Aussie Dp. (ST185)
SO BE IT
MARLON1211
Postby Gary » Mon Aug 23, 2004 1:47 pm
Yes. just remove the extra stud from the flange.
93 ST185
Gary
Postby coyoteboy » Wed Aug 25, 2004 7:26 pm
Is the 20B a bolt-on HP upgrade at the same pressure, or is it just going to allow greater performance improvement through other mods. I've heard claims of 30bhp increase just by adding the 20B at the same pressure - seems a tad odd to me.
J
coyoteboy
Postby alltracman78 » Thu Aug 26, 2004 12:58 am
More efficient turbo will create less heat=more power
Postby Kyoto » Thu Aug 26, 2004 2:02 am
I too have been looking into getting one of these for my 165 however out of the two places i called thus far, one of them basically laughed at me, and the second said i would have real problems locating one without buying a front-cut. I am in Melbourne, Australia by the way...
So i have two questions. Have you guys found them hard to come by in the states? And secondly, wll i need to upgrade my fuel system to run the 20b? if so what with?
Cheers
Kyoto
