Sard 63566 Injectors
Postby Punknoodle » Thu Nov 01, 2012 4:11 am
Hello,
I will be getting my Celica tuned shortly and am currently considering buying a Flex Fuel sensor and installing this along with bigger injectors so I can tune and run the car on E85. I have the Gen 1 head, and hence I have a Gen 1 fuel rail and top feed injectors, and just want opinions as to whether these injectors will be suitable? I was basically just looking for low impedance, 800cc injectors with a 2 nozzle head. I believe I need an oval coupler as opposed to square. This injector seems to do it - I'm looking at around AU $600 for a set of four.
Punknoodle
Re: Sard 63566 Injectors
Postby Mafix » Thu Nov 01, 2012 1:45 pm
i've got a set of top feed 780cc rc injectors (large bore, low impedence) with harnesses i'll send you for way less! you will need to drill the injector holes in the rail. i used them with my stock 165 rail and they work great.
Postby Punknoodle » Thu Nov 01, 2012 7:24 pm
PM'd mate.
Punknoodle
