Electronic boost controller recommendations
Re: Electronic boost controller recommendations
Postby celica_gtx » Fri Mar 08, 2013 3:29 pm
gt4tified wrote:You'll want to use the injector duty function, the rpm, speed, boost....all these can be displayed simultaneously....but decide which is most important since with each new parameter monitored, the display area for each gets smaller.
what bout tunin I wanted to give it a shot my self. I wanna be at 1bar and its my dd. Then tune thro gears raise or lower dependin on feel. Also my turbo is a .50 machined ct26 w stock wastegate this gunna be good enough?
transformation has BEGUN!!!
90GT W/ 90 3SGTE/ SOLD
91 ALL-TRAC 215 w 205 swapd
10 Scion Xb-kid hauler
celica_gtx
Postby gt4tified » Mon Mar 11, 2013 7:28 pm
1 bar should be fine for that turbo. is your intercooler setup fmic or the oem tmic?
use the learn function in the beginning...then start with incremental adjustments to get it to where you want.
gt4tified
Images: 5
Postby celica_gtx » Tue Mar 12, 2013 2:15 am
i got it wired up..
problems boost not changing.
the boost gauge is reading -230mmhg
and will change + or - 2
is my boost snr bad?
also on the solenoid which ports do u guys have n goin to where
so i can check my work.
other than that everything else reads
celica_gtx
