Just got my head and valves back from Swain Tech (pics)
Postby BADNEWS » Wed Jan 16, 2013 12:43 pm
Got my head and valves in the mail yesterday from Swain Tech. They did a thermal coating on the combustion chambers, exhaust posts, face of the valves, Radius side of the valves, and a low friction coating on the valve stems. Thermal coating is a white/grey color, and the low friction coating is dark grey color.
I'm also having the bottom end done too. Piston tops with a thermal gold coat, Piston skirts with the low friction coating, all my bearings with the low friction coatings, and my crank and rods with an oil shed coating. That should be back to me in a week or so.
865AWHP, 591 torque
BADNEWS
Re: Just got my head and valves back from Swain Tech (pics)
Postby ZeroDrift » Wed Jan 16, 2013 1:34 pm
Looks good, but I honestly was expecting to see the valve seats and the mating surface on the valve masked off. Are you having the machining work done on these parts after coating? I'll be doing the same to my valves, but I won't be doing much to the combustion chamber as I don't have an ultrasonic cleaner large enough.
Postby Rpz123isme » Wed Jan 16, 2013 1:54 pm
All that coating is not wise. Only thing you should do is sleeve the block and sent it to have nick-sil.
Hesperia, CA
Rpz123isme
Postby BADNEWS » Wed Jan 16, 2013 5:01 pm
ZeroDrift wrote:Looks good, but I honestly was expecting to see the valve seats and the mating surface on the valve masked off. Are you having the machining work done on these parts after coating? I'll be doing the same to my valves, but I won't be doing much to the combustion chamber as I don't have an ultrasonic cleaner large enough.
I have to lap the valves now till all the coating is off.
865AWHP, 591 torque
BADNEWS
Postby BADNEWS » Wed Jan 16, 2013 5:06 pm
Rpz123isme wrote:All that coating is not wise. Only thing you should do is sleeve the block and sent it to have nick-sil.
I did research and saw how these coatings do improve engine efficiency. And sleeving your block more often actually weakens it. Most of the time you take out so much material that the stock cylinder wall ends up cracking behind the sleeve. Which is why I went with a 5S block and filled.
865AWHP, 591 torque
BADNEWS
Postby warracer » Thu Jan 17, 2013 2:30 am
MEEEAN STUFF
____________
ST185H A-Spec:
-IHI VF28 -BC Racing coilover
-Yonaka FMIC -Swift Spring
warracer
Postby klue » Fri Jan 18, 2013 3:01 am
The coating should definitely help once it stays on. My only concern would be the finish, it seems pitted and in consistent. I usually just do some polishing on CC and that seems to work well enough for me
Cheers
Postby RedCelicaTRD » Fri Jan 18, 2013 3:52 am
Looks good. Stuff works great, don't mind the peanut gallery.
Postby ZeroDrift » Fri Jan 18, 2013 4:42 am
I'm all for ceramic coating. Honestly; I offer that service at my business. Forgive me for saying, but that does look a little quick and messy. The pitting and whatnot does seem disconcerting. Check to see if it has been applied evenly over the valves and head. At the very least email them about it and verify things. I've heard great things about the company in the past and the quality was not what I was expecting.
Postby l0ch0w » Fri Jan 18, 2013 4:50 am
For all that work, why didn't you have a mild bowl blend and port de-shrouding done in the combustion chamber? Just because you have a Swaintech coating now doesn't mean that hot spots cant develop on the valve shrouds. Maybe I'm missing something, but the caliber of your build would have lent me to believe that you were looking for the best of the best. Im not ragging on Swaintech or their product. I in fact have my piston crowns coated in the stuff. Im just concerned that maybe you may have skipped a vital step in your quest for big power.
Porting isn't really worth much with the 3S head, and most know that, but cleaning things up can pay off. Most of the successful high HP 3S guys I know have at least cleaned up the casting flaws on the ports, done mild bowl blending, and de-shrouded and polished up the combustion chamber to reduce hot spots. Remember, hot spots develop on pointy or crevice areas, which is why high power heads are nice and smooth in their combustion chambers...
Andrew
1991 Red Alltrac
l0ch0w
Postby BADNEWS » Fri Jan 18, 2013 10:39 am
l0ch0w wrote:For all that work, why didn't you have a mild bowl blend and port de-shrouding done in the combustion chamber? Just because you have a Swaintech coating now doesn't mean that hot spots cant develop on the valve shrouds. Maybe I'm missing something, but the caliber of your build would have lent me to believe that you were looking for the best of the best. Im not ragging on Swaintech or their product. I in fact have my piston crowns coated in the stuff. Im just concerned that maybe you may have skipped a vital step in your quest for big power.
I had my head done by Class One Inc. who does all of Mike Reichen's engine work. They never mentiones it to me. Even all the pits in my combustion chamber, I was told is fine and not worth the time sanding all the material out completely. As for the de-shroud, I have seen that on the MR2 boards a lot. One guy posted pics of how it went further out than the headgasket. He had ATS do his headwork. You can see from my coatings where the headgasket is. There is no room to take material away. The headgasket is 1 or 2mm bigger than my bore. And if you do deshroud, the block is still right there in your way. So I never even mentioned it to them for their opinion.
The big thing we did with my head is port the exhaust side to flow more. Stock the intake side flows more than the exhaust side. Class One told me, they like to get the exhaust side to flow 10% more on turbo motors than the intake. So that is where most of the head work was done. I'm in the 7% range now depending on lift.
865AWHP, 591 torque
BADNEWS
Postby Hotrodhendrix » Fri Jan 18, 2013 1:02 pm
Thats alot of coating yep yep. Should be a beast of a motor once its all said and done. Now of course if you get bored or anything you may give it to me... Your welcome :P
~James
Postby BADNEWS » Tue Feb 05, 2013 9:26 pm
Got my crank back from Swain today. Need to gap my rings and then it's assembly time. I'll post a pic of everything when I get to assembling it. Should be a couple weeks.
865AWHP, 591 torque
BADNEWS
