Finished my Direct Port Nitrous. PICS!
Postby Spectra1 » Sat Jan 26, 2013 2:51 am
I finally got around to finishing the hard lines on my direct port nitrous set up. Enjoy!
I installed the foggers between the divides within the split runners, I had to port the divider material back about 1 1/2 inches. Now the foggers are not inline with the air flow which should help keep things moving along.
Here is the hard lines I just finished bending and mounting up
Now all bolted to the motor
Let me know what you guys think.
93 St185 DD
90 ST185 - Project
Spectra1
Re: Finished my Direct Port Nitrous. PICS!
Postby polm » Sat Jan 26, 2013 4:48 am
Verrrry nice! Post some drag times when you get everything running!
polm
Postby underscore » Sat Jan 26, 2013 3:34 pm
Nice work! Are those splitters attached to the motor at all?
Postby Spectra1 » Sat Jan 26, 2013 6:24 pm
Will do. It might be awhile before I get to that point though.
No the distributor blocks are not attached to anything they just float about an inch above the block. I will probably mock up some bracket eventually.
93 St185 DD
90 ST185 - Project
Spectra1
Postby warracer » Sat Jan 26, 2013 11:30 pm
well thats seems violent enough ! :evil:
____________
ST185H A-Spec:
-IHI VF28 -BC Racing coilover
-Yonaka FMIC -Swift Spring
warracer
Postby Mafix » Mon Jan 28, 2013 1:13 pm
cool. i'm assuming your tvis plate has no center and the cylinder head is knife edged on the bridge?
Postby Spectra1 » Mon Jan 28, 2013 2:50 pm
Mafix wrote:cool. i'm assuming your tvis plate has no center and the cylinder head is knife edged on the bridge?
Yes the tvis plate has been gutted and the center removed, im to cheap to just buy one of those phenolic plates :) . As for the cylinder head I have not really done a whole lot to it since I bought it from the owner that built it. There appears to be some porting work done in that area and it appeared to me to be sufficient. Do you think I need to really give it a good knife edge?
93 St185 DD
90 ST185 - Project
Spectra1
Postby Mafix » Mon Jan 28, 2013 8:18 pm
it's probabily not that critical.
and i'm also too cheap to buy and shatter another spacer. gutted tvis for me.
Postby gt4tified » Wed Feb 27, 2013 6:06 pm
Supplemental question....did you have to recess the splitter/bridge by cutting a "C" section back into the manifold, to accommodate for the installation of the solenoid nozzle away from the flange?
gt4tified
Images: 5
Postby Spectra1 » Wed Feb 27, 2013 10:11 pm
Yes I had to port all the material out of the splitter/bridge. I did it that way so my nozzles would not disrupt air flow.
93 St185 DD
90 ST185 - Project
Spectra1
Postby klue » Wed Feb 27, 2013 11:46 pm
anything planned to compensate for the lean condition that intake manifold produces?
Postby Spectra1 » Thu Feb 28, 2013 4:00 am
The intake manifold was made by HUX and uses the stock extrude honed runners with a larger better flowing weld on phlem. I have not run it yet on the car so I cant really comment on how well it does in regards to addressing lean conditions. I will be running exhaust temp probe in the #3 exhaust runner so that should give me some important data.
klue wrote:anything planned to compensate for the lean condition that intake manifold produces?
93 St185 DD
90 ST185 - Project
Spectra1
Postby klue » Thu Feb 28, 2013 10:28 pm
good shit!
Eric makes quality stuff so I would expect that condition is addressed. As far as the extrude honing process goes it should technically balance the flow. I think the flow issue is in part due to the TB placement favoring 2 and 3 but I guess we will find out
good on ya
cheers
Postby aus jd 2703 » Thu Aug 01, 2013 1:45 am
did you ever run this?
what supporting mods have u done? ecu forged pistons anything?
what shot did you run?
been tempting to run a 50 wet shot on mine because i have a kit lying around...
aus jd 2703
Postby Spectra1 » Thu Aug 01, 2013 2:45 am
aus jd 2703 wrote:did you ever run this?
Not yet. The project has been moving slowly but unfortunately I will be shutting it down for the next year. Im moving to AZ for school and did not have the time to get it running yet so hopefully next summer it will be done. Supporting mods thus far include: 5s stroker crank, shot peened rods, forged pistons, apr everything, fully upgraded fuel system, FMIC, aftermarket intake and exhaust manifolds, gt35r turbo, autronic ecu, egt probe, af meter, meth injection....etc. When I finally get it running im planning on running around a 50-80 shot.
93 St185 DD
90 ST185 - Project
Spectra1
