Supercharged 3sgte~3sgze??
Postby Overtriped » Sat Feb 02, 2013 4:57 pm
I've got a connection that has a whipple* s/c 2300cc capable of 30 PSI what do you think ?!?! Has anyone done this? [Image
90 ST185~205
04 Tundra V6 5spd 2wd
TOYOTA JUNKIE
Overtriped
Re: Supercharged 3sgte~3sgze??
Postby underscore » Sat Feb 02, 2013 5:15 pm
Where on earth would you mount it?
Postby fussellbug » Sat Feb 02, 2013 6:09 pm
the whipple superchargers are made for mounting on the top of a V-block engine, so I can't see any feasible way to use it on an inline-4. If you have your heart set on supercharging, check out the Rotrex supercharger used on a Beams 3S-GE: http://www.mr2.com/forums/beams-owners-group/Toyota-MR2-33226-supercharger-109.html He basically doubled the base N/A horsepower using a centrifugal supercharger.
fussellbug
Images: 36
Postby Overtriped » Sat Feb 02, 2013 6:17 pm
typically they get mounted on the top near the intake, mine will have an IC so that has to fit in there too...I have a spare hood that I could modify. Keep In mind these supercharges are common and is reasonably priced used. Why wouldn't it boost if its hooked up via belt to the crank? I feel it's just a matter of building the right manifold and brackets...
90 ST185~205
TOYOTA JUNKIE
Overtriped
Postby sinerasis » Sat Feb 02, 2013 10:24 pm
I'm sure you could make it work, but why would you want a supercharger instead of a turbo? Especially on a motor that comes turbocharged?
Jeff
1989 ST165 Black
sinerasis
Postby Overtriped » Sat Feb 02, 2013 10:41 pm
More power for my dollar, I feel it's a cool alternative, less lag is good too.
90 ST185~205
TOYOTA JUNKIE
Overtriped
Postby Ghost1 » Sat Feb 02, 2013 11:50 pm
i been researching the 5sgze for a while for my gts. its more cost effective just to put a 3sgte. but i was thining of using a different sc.
Ghost1
Postby sinerasis » Sun Feb 03, 2013 1:31 am
It'd sure be different, but unless you just get parts for free I can't imagine it'd be more cost effective to remove a decent turbo system (even if it's just a starting point) and install a supercharger. If anything it'd be a wash money wise. Especially if you're looking to do ~30psi. That's expensive no matter what you do.
Properly built and tuned turbo systems don't have lag issues.
Could be cool though, just not something that would really make sense IMO.
Jeff
1989 ST165 Black
sinerasis
Postby underscore » Sun Feb 03, 2013 3:05 am
so again, where would something that big fit? On top of the valve cover?
Postby Overtriped » Sun Feb 03, 2013 5:24 pm
Yeah, basically. Pretty sure the hood would have to be cut- ill make it fit. The stock intake manifold would be replaced with a welded aluminum one. I haven't measured it but this build hasn't started yet, we will also be supercharging a 2jz aswell in the future. Another project that's In the works now is a twin charged Camry Image
90 ST185~205
TOYOTA JUNKIE
Overtriped
Postby OutToWinPAHC » Sun Feb 03, 2013 6:24 pm
sinerasis wrote:I'm sure you could make it work, but why would you want a supercharger instead of a turbo? Especially on a motor that comes turbocharged?
TWIN CHARGING!!!!
1990 ST185 All-Trac 54trim
1993 Nissan Skyline R33 GTS25T-M widebody built 60trim R34 NEO AEM-Series 2
OutToWinPAHC
Postby Overtriped » Mon Feb 04, 2013 12:10 am
In this situation it does seem plausible to twincharge. I do want to have an IC. We could make the intake piping work since I'll be going that direction on the outlet from the blower anyway.
90 ST185~205
TOYOTA JUNKIE
Overtriped
Postby klue » Mon Feb 04, 2013 3:46 am
DOO it!
Postby CMS-GT4 » Mon Feb 04, 2013 3:49 am
There is pics of the twin charged st205 you could look at around here somewhere for inspiration.
Postby Awesome-Trac » Mon Feb 04, 2013 6:22 am
There's a twincharged 88 mr2 here in Cali
•Daniel
Awesome-Trac
