5S-FE Swap
5S-FE Swap
Postby Killtodie » Sun Feb 17, 2013 8:05 am
I have a low mileage 5S bottom end sitting in my garage I got from a friend for free. Thinking about swapping it for current 3S. My engine right now is burning oil and maybe coolant. It currently needs a timing kit. I have leaky cam shaft seals and crank seals. So its also leaking oil. So I need a timing kit and a gasket kit, so like $250ish or so. Maybe a new headgasket if its burning coolant, I sent my oil out for analysis, so that will tell me that.
For less money I can get just ARP studs, a new headgasket and put a perfectly working engine in that needs nothing serviced on it. I hear that the 5F and 3S are essentially the same blocks and do not need anything else done other than a turbo head from my ST165.
Is this a straight swap? Do I need anything custom done, such as mounts, lines, grinding, different senders/harness?
1988 Chrysler Conquest
1988 Toyota Celica All-Trac
Killtodie
Re: 5S-FE Swap
Postby OutToWinPAHC » Sun Feb 17, 2013 12:27 pm
I thought there was a good bit of grinding to be done on the blocks webbing to make it clear the transfer case.
1990 ST185 All-Trac 54trim
1993 Nissan Skyline R33 GTS25T-M widebody built 60trim R34 NEO AEM-Series 2
OutToWinPAHC
Re: 5S-FE Swap
Postby jaydog82 » Sun Feb 17, 2013 11:01 pm
search 5sgte
jaydog82
Re: 5S-FE Swap
Postby Killtodie » Mon Feb 18, 2013 6:36 pm
I've searched, found some info but not exactly what I'm doing. Most of it has been non alltrac swaps or 5S into Camreys or something
Killtodie
Re: 5S-FE Swap
Postby phattyduck » Mon Feb 18, 2013 6:48 pm
You need to get the water/coolant passages right, the internals right, the timing right (extra deck height affects timing), transfer case clearance, turbo oil/water plumbing and probably a few other things.
'99 4Runner SR5 4WD 5VZ-FE
phattyduck
