What kind of manifold is this?
Postby kn0wledge185 » Sun Feb 17, 2013 8:11 pm
Went over to a friend's house and saw this manifold.......
kn0wledge185
Re: What kind of manifold is this?
Postby BayAreaAT® » Sun Feb 17, 2013 9:38 pm
Is that 205 antilag?
Chris M.
91 ST185 "money sponge"
Ford Ford (Daily Grind)
R1 Yamaha ( Need for speed)
Ford F150
Chrysler 300c Hemi baby!!
BayArea,California
www.Boost2maxx.com
BayAreaAT®
Postby BayAreaAT® » Sun Feb 17, 2013 9:41 pm
Chris M.
Ford F150
BayArea,California
www.Boost2maxx.com
BayAreaAT®
Postby kn0wledge185 » Sun Feb 17, 2013 10:06 pm
Nice...... so my next question is..... what are those lines connected to?
Thanks for finding that
kn0wledge185
Postby jaydog82 » Sun Feb 17, 2013 10:51 pm
they are part of the anti lag system that is controlled by the computer, they are disabled from the factory.
jaydog82
Postby jaydog82 » Sun Feb 17, 2013 10:59 pm
viewtopic.php?f=50&t=37224
Anti-Lag
The Group A was the first production car I know of with anti-lag standard, although again not operational. The system uses an ECU signal to switch two VSV's on the back of the block which provide vacuum (via a canister) to the special bypass valve fitted right beside the entrance to the IC. This heavy duty metal valve has a poppet valve which when opened directs some of the air (which usually all goes through the BOV) down four metal tubes into the exhaust manifold. A special manifold has a hole just after each exhaust port. A small heatshield sits between the manifold and the intercooler.
How do you make it work? You don't.
Anti-lag is *very* hard on turbos due to the shockwaves and high temperatures produced. Unless you have a rally team budget, forget it.
Here is some of what you need to do to activate it. My bypass valve seems to be jammed shut, maybe it has an internal spacer to stop it opening. The fittings connecting the pipes to the manifold are also not drilled though. With those aspects fixed the system will mechanically work. The VSV's are wired to the ECU, however an aftermarket ECU is needed to apply 12V to make them work. I'm guessing that (like most systems) the ECU retards the timing while continuing fuel injection. The mixture burns in the manifold, keeping the turbo spinning. This is very harsh on the system, therefore the pipes are just to supply cool air to keep temperatures down (conjecture!).
from http://gtfour.supras.org.nz/homologation.htm
jaydog82
Postby gearhead313 » Mon Feb 18, 2013 2:10 am
If you sat down with some basic knowledge of the system, its not hard to get it working. A standalone actuation is necessary, forget about how cool toyota was using its ecu to do it. I've seen one car on the street with it and it was thee most annoying thing ever. It is definitely a longevity killer!
ST165 counter:
#2597 - fail
#3193 - fail
#xxxx - sold
#4598 - sold to Canada eh
gearhead313
Postby Hic » Mon Feb 18, 2013 5:44 am
Yes, but that stock manifold will die in matter of minutes.
Wrc cars had inconel manifold. Not iron.
Hic
Postby kn0wledge185 » Mon Feb 18, 2013 3:18 pm
That's what we are trying to figure out..... how it is connected.... to what canister...n everything
kn0wledge185
Postby athousandleaves » Mon Feb 18, 2013 9:48 pm
Don't bother with it, its all for show.
read this thread and you'll see its more trouble than its worth: viewtopic.php?f=7&t=35067
1992 Red GT-FOUR RC 626•1800
1992 White turbo4WD
athousandleaves
Postby kn0wledge185 » Tue Feb 19, 2013 12:33 am
Dam that really sucks....... I would of love to see that system connected
kn0wledge185
