Engine build
Engine build
Postby psipwrd » Sun Feb 17, 2013 9:00 pm
I recently blew a head gasket and decided to do a rebuild. The plan is to go with forged internals and basic bolt-ons for now. Once I'm back in the US, the goal is about 400awhp .
The catch is I don't want to deal with stand-alone engine management or custom tuning while in Italy.
Here's what's on the car:
3" downpipe
boost gauge
mbc
Here's what I ordered for the build so far:
cometic top/bottom gasket kit
aisin oil and water pump
timing belt
radiator
thermostat
ACT HD clutch
And what I'm looking at:
cp pistons/eagle rods
3" exhaust
ARP head studs
silicone radiator hoses
turbo rebuild
What else would you guys recommend for the build?
psipwrd
Re: Engine build
Postby gearhead313 » Mon Feb 18, 2013 2:12 am
Its going to be very difficult to get a reliable system functioning @ 400awhp with stock yota controls. I'd seriously consider some sort of alternative...
ST165 counter:
#2597 - fail
#3193 - fail
#xxxx - sold
#4598 - sold to Canada eh
gearhead313
Re: Engine build
Postby Hic » Mon Feb 18, 2013 5:42 am
I would say, impossible :)
Or better, no way in hell.
Hic
Re: Engine build
Postby Fox 21 Alpha » Mon Feb 18, 2013 6:55 am
Maybe look at an ATS tune if your dead set against stand alone
Fox 21 Alpha
Re: Engine build
Postby psipwrd » Mon Feb 18, 2013 6:56 am
Guys, you make me feel like a noob! :rofl:
I don't want to do the 400hp and stand-alone in italy, just reliable built block!
Once back in the US, I'll upgrade the turbo, fueling, and engine management.
psipwrd
Re: Engine build
Postby 4rsnduction » Mon Feb 18, 2013 7:05 am
If your just rebuilding then concentrate on the bottom end for reliability and the head for extra power.
- Head gasket (1.8mm or thicker is a good option)
- Pistons
- Rods (X-beam if you can find them)
- Steel backed bearings
- Crank work if you want that extra little bit (shot peen - knife edge)
- Oil pump (oil pump can be modified by a proper engine builder, this will allow for more pressure at idle, something that is needed with an external cooler and relocated oil filter)
4rsnduction
Re: Engine build
Postby underscore » Mon Feb 18, 2013 2:14 pm
4rsnduction wrote:- Oil pump (oil pump can be modified by a proper engine builder, this will allow for more pressure at idle, something that is needed with an external cooler and relocated oil filter)
As someone found in another thread, you can use one off a newer 5SFE (can't remember the exact years) to get a higher pressure pump.
Re: Engine build
Postby psipwrd » Tue Feb 19, 2013 8:57 pm
Thanks for the input!
psipwrd
Re: Engine build
Postby psipwrd » Thu Feb 28, 2013 9:39 pm
I got my estimate today and the rebuild is not the way to go. I got quoted $4300 for labor and $1000 tax! $5300 for labor! That's not including the $$$$ spent, and $$$$ for forged internals, valves, headstuds and rod bearings, and other odds and ends like hoses.
A quick search pulled up a few engines from $1000-1800. May I ask where everyone's getting their engines from?
Also, I read through the ST205 engine/ecu into ST185 thread. Is this something I should ask of an italian mechanic with language a barrier?
psipwrd
Re: Engine build
Postby psipwrd » Sun Mar 10, 2013 3:37 pm
After a month of spinning tires, I got good news today. ATS delivers to APO! :D
psipwrd
