1st gen 3sgte fuel rail fit a 2nd gen
Postby alvinguy » Thu Feb 28, 2013 1:32 am
Anybody know if the 1st Gen 3sgte will fit a 2nd Gen? Thanks
alvinguy
Re: 1st gen 3sgte fuel rail fit a 2nd gen
Postby brutekiller787 » Thu Feb 28, 2013 2:34 am
yes it will fit. you will need to fabricate brackes to hold the fuel rail as the mounting points on the head are at a different angle and you will need new lower injector seals as the st165 one's are too small. common solutions are to cut the bottom off the 2nd gen fuel rail or 96 5sfe injector seals
brutekiller787
Postby alvinguy » Thu Feb 28, 2013 3:14 am
Thank you!
alvinguy
Postby brutekiller787 » Thu Feb 28, 2013 3:31 pm
I can try and get some pictures of my setup if you want
brutekiller787
Users browsing this forum: Google [Bot], Yahoo [Bot] and 1 guest
